주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Moto G 3rd Generation Display Replacement
필요한 것
동영상 개요
  1. Motorola Moto G 3rd Generation Display Replacement, Display: 1 단계, 이미지 2개 중 1개 Motorola Moto G 3rd Generation Display Replacement, Display: 1 단계, 이미지 2개 중 2개
    • Use your fingernail to pry under the notch on the bottom of the phone and remove the back cover.
    • Make sure to fully power off the phone before you begin disassembly.
    댓글 쓰기
  2. Motorola Moto G 3rd Generation Display Replacement: 2 단계, 이미지 2개 중 1개 Motorola Moto G 3rd Generation Display Replacement: 2 단계, 이미지 2개 중 2개
    • Use a heat gun or an iOpener as a heating tool. This guide explains how to use the iOpener.
    • Evenly apply heat to the edges of the touchscreen to loosen the adhesive. Continue to Step 3 once the edge of the screen is warm to the touch.
    • Do not let the iOpener/heat gun remain on one spot for too long. Excess heat can damage the phone.
    • When reassembling the phone, use the iOpener/heat gun to help the adhesive fuse to the new screen. Heat the screen edges, apply pressure to the screen, and hold the screen in place until it is secure.
    댓글 쓰기
  3. Motorola Moto G 3rd Generation Display Replacement: 3 단계, 이미지 3개 중 1개 Motorola Moto G 3rd Generation Display Replacement: 3 단계, 이미지 3개 중 2개 Motorola Moto G 3rd Generation Display Replacement: 3 단계, 이미지 3개 중 3개
    • As the adhesive loosens, pry up an edge of the screen with a plastic opening tool or an opening pick. A suction cup may also be useful here.
    • Use an opening pick to hold that edge in place and continue this process around the entire screen, applying more heat as necessary.
    • Avoid damaging the LCD screen connector while prying along the screen edges. It is located on the left edge of the phone, across from the volume controls.
    • During reassembly, new adhesive may need to be applied over the old adhesive to properly secure the screen.
    댓글 쓰기
  4. Motorola Moto G 3rd Generation Display Replacement: 4 단계, 이미지 3개 중 1개 Motorola Moto G 3rd Generation Display Replacement: 4 단계, 이미지 3개 중 2개 Motorola Moto G 3rd Generation Display Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $8.95
    • Use a plastic opening tool to flip up the lock on the display cable ZIF connector.
    • Pull the display cable from its socket on the motherboard.
    • When installing a new display, carefully remove all remaining adhesive from the phone, and clean the adhered areas with isopropyl alcohol (90% or greater) and a lint-free cloth. Install the display using pre-cut adhesive or a strong double-sided tape such as Tesa 61395. Turn your phone on and test your repair before sealing the display in place.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 52명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Ahnaf Siddiqui
회원 가입일: 02/10/16
663 평판
안내서 1개를 작성함
USF Tampa, Team 1-3, Nance Spring 2016 USF Tampa, Team 1-3, Nance Spring 2016 회원
USFT-NANCE-S16S1G3
4 회원들
안내서 27개를 작성함
20가이드 댓글
If your original screen has any adhesive tape on it's back (near to where the flat cable connects to the board), remove it from the original and put on the replacement piece, i've spent a lot of hours trying to undestand why my replacement screen worked fine out of the phone, but had some problems after puting it on the phone. After a lot of time i noticed this tape and did what i said, and the problem stoped, aparently is some kind short circuit betwen board and the screen aluminum back. Sorry bad english.
Leonardo Assef - 답글 공유
Could you explain where the addhesive was a little bit more? I have my screen falling off from that corner and I've tried adding more addhesive but still... Wondering if the replacement is faulty.. I don't have the original anymore
rpalesh - 답글 공유
Thank you soooooo much! I just had the same problem! many thanks for posting und best wishes. You are a great human being!
Felix Eikenberg - 답글 공유
I had the same problem, now i ordered better adhesive. where is this tape? Do you have a picture?
sebastianwolz - 답글 공유
In my case it was a yellow stripe unter the ZIF connector that prevents the socket from connecting with the back of the screen.
Julian Zimmermann - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 75
전체 시간: 58,701
