소개
This guide demonstrates how to replace the LCD display panel in your 2022 Motorola Moto G.
Note: This procedure is for a screen without the frame (a.k.a. chassis). If you're replacing the screen with a genuine Motorola screen pre-installed in a new frame, follow this guide instead.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
필요한 것
Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
Press firmly to eject the tray.
Take note of the following seams along the edge of the phone:
Screen seam: This seam separates the display panel from the frame. Don't pry at this seam.
Bezel seam: This is where the plastic back cover meets the rest of the phone. It's held in place by plastic clips. This is where you should pry.
Insert an opening tool in the bezel seam halfway between the bottom-right corner of the phone and the power button.
Insert an opening pick in the gap you just created.
Slide your opening pick toward the bottom-right corner of the back cover and release the clips.
Continue sliding your opening pick towards the bottom left corner to unclip the bottom edge of the back cover.
Slide your opening pick toward the top left corner to unclip the left side of the back cover.
Slide your pick around the top left corner and along the top edge to release the clips.
With SIM card slot facing you, swing the back cover open and away from you like you're opening a book.
Rest the cover parallel to the frame.
Use a PH00 screwdriver to remove the two 3.9 mm-long screws securing the power button cable bracket.
Use the pointed end of a spudger to pry up and disconnect the power button's press connector.
Use your Phillips screwdriver to remove the eight 3.9 mm-long screws securing the motherboard cover.
Insert an opening pick between the bottom-left corner of the cover and the motherboard.
Pry up to release the cover's small clips securing it to the frame.
이 단계에 사용된 도구:Tweezers$4.99
Grab and remove the motherboard cover from the phone.
Use the pointed end of a spudger to pry and disconnect the battery's press connector.
Heat an iOpener and apply it to the left edge of the screen for about two minutes.
Apply the isopropyl alcohol into the gaps between the sides of the battery and the frame.
Apply a suction cup to the battery, as close to the center of the right edge as possible.
Insert an opening pick between the right edge of the battery and the frame.
Pull on the suction cup and pry the battery upward.
Use the pointed end of your spudger to pry and disconnect the display cable's press connector.
Heat an iOpener and apply it to the display cable for two minutes.
Grab the display's ribbon cable near the connector.
Peel the cable toward the bottom of the phone until it's completely separated from the frame.
Place the back cover over the frame of the phone
Press around the perimeter to re-engage the clips securing the cover.
Apply a suction cup to the screen, as close to the center of the top edge as possible.
Insert an opening pick vertically into the shallow cutout in the top of the glass, as far right as possible.
Pull up on the suction cup with a strong, steady force.
Angle the opening pick to about 30 degrees, firmly slide it toward the right corner of the display, and separate the adhesive.
Slide the opening pick toward the bottom right corner to separate the right edge's adhesive.
Grab and pull the bottom of the display panel down and away from the frame, making sure to thread the display cable through its slot.
Once the display cable is free, remove the panel from the frame.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
How do I replace the edge of my phone just need some help trying to do that
Johnny Boy - 답글
Hi Johnny,
If you're looking to replace the border around the perimeter of your phone, then this would be a back cover replacement. The back cover includes the edge of the case, right up to the screen bezel.
