주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nabi Jr Camera Replacement
필요한 것
    1. Nabi Jr Camera Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
      • Remove the red rubber case from the device. This should come off with ease.
      댓글 쓰기
    2. Nabi Jr Camera Replacement: 2 단계, 이미지 1개 중 1개
      • Turn the device so the screen is facing away from you.
      • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
      댓글 쓰기
    3. Nabi Jr Camera Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the device casing using a small plastic pry bar.
      • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
      댓글 쓰기
    4. Nabi Jr Camera Replacement: 4 단계, 이미지 1개 중 1개
      • After loosening the back cover, remove it from the device so you can get at the innards.
      댓글 쓰기
    1. Nabi Jr Camera Replacement, Camera: 5 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Using tweezers remove tape that connects the board to the camera's ribbon cable.
      • The ribbon cable is inserted into a slot on the board.
      • Lift the slot's locking tab up to easily remove the ribbon cable from the board.
      • May require force
      댓글 쓰기
    2. Nabi Jr Camera Replacement: 6 단계, 이미지 1개 중 1개
      • Place the new camera piece in place of the old and plug its ribbon cable back into the respective slot on the board.
      • Make sure the locking tab on the slot is in its up position before inserting tape.
      • Once the tape is inserted press the locking tab back to its down position to securely fasten the ribbon cable.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Kaila Joy
회원 가입일: 03/24/15
86 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G3
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 26
전체 시간: 561
