주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
New Nintendo 2DS XL Front Buttons Replacement
필요한 것
  1. New Nintendo 2DS XL Front Buttons Replacement, Prepare for disassembly: 1 단계, 이미지 1개 중 1개
    • Before you begin, power off the console and remove:
    • The stylus
    • Any game cartridge
    • The microSD card
    댓글 쓰기
  2. New Nintendo 2DS XL Front Buttons Replacement, Remove the back cover screws: 2 단계, 이미지 1개 중 1개
    • Use a tri‑point Y00 screwdriver to remove the four 6 mm‑long screws located at the four corners of the bottom panel.
    댓글 쓰기
  3. New Nintendo 2DS XL Front Buttons Replacement, Release the back cover clips: 3 단계, 이미지 2개 중 1개 New Nintendo 2DS XL Front Buttons Replacement, Release the back cover clips: 3 단계, 이미지 2개 중 2개
    • Use a spudger to gently pry around the two short edges and front edge (with the stylus cut‑out) to release the clips securing the back cover.
    • Swing the back cover open from its front edge to release the clips along the hinge edge. Don't remove it fully—three cables are connecting it to the motherboard (two on each side and one in the rear).
    댓글 쓰기
  4. New Nintendo 2DS XL Front Buttons Replacement, Disconnect the back cover: 4 단계, 이미지 3개 중 1개 New Nintendo 2DS XL Front Buttons Replacement, Disconnect the back cover: 4 단계, 이미지 3개 중 2개 New Nintendo 2DS XL Front Buttons Replacement, Disconnect the back cover: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
    • Fold the back cover over the hinge edge, keeping the cable connected. Don't strain the cable.
    댓글 쓰기
  5. New Nintendo 2DS XL Front Buttons Replacement, Battery Removal: 5 단계, 이미지 2개 중 1개 New Nintendo 2DS XL Front Buttons Replacement, Battery Removal: 5 단계, 이미지 2개 중 2개
    • The battery is lightly adhered to its enclosure.
    • Use the flat end of a spudger to gently pry the battery out of its plastic enclosure.
    댓글 쓰기
  6. New Nintendo 2DS XL Front Buttons Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 New Nintendo 2DS XL Front Buttons Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • There are 8 ribbon cables that need to be removed as shown in the picture.
    • 2 of connectors (in green) are friction fit, unlike the rest of the connectors. Remove the cable by pulling it out gently flat in the arrow direction. Do not attempt to open or unlatch these connectors in any way. Doing so will break them.
    • For the remaining 6 (in red), use a pair of tweezers to flip the latches up and pull the ribbon cable out.
    • Note that the second picture shows a broken ribbon connector next to the joystick ribbon connector (to the right of the red arrow). Do not attempt to unlatch this connector as shown in the picture!
    댓글 쓰기
  7. New Nintendo 2DS XL Front Buttons Replacement: 7 단계, 이미지 2개 중 1개 New Nintendo 2DS XL Front Buttons Replacement: 7 단계, 이미지 2개 중 2개
    • Unplug the following wires from the motherboard using a pair of tweezers.
    댓글 쓰기
  8. New Nintendo 2DS XL Front Buttons Replacement: 8 단계, 이미지 2개 중 1개 New Nintendo 2DS XL Front Buttons Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the seven 4.4 mm screws using a J00 (or iFixit's Phillips #00) screwdriver bit.
    • Remove the motherboard from the device.
    댓글 쓰기
  9. New Nintendo 2DS XL Front Buttons Replacement, Button Removal: 9 단계, 이미지 3개 중 1개 New Nintendo 2DS XL Front Buttons Replacement, Button Removal: 9 단계, 이미지 3개 중 2개 New Nintendo 2DS XL Front Buttons Replacement, Button Removal: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Lift off the rubber cover on the A, B, X, and Y buttons.
    • Using tweezers, lift out the buttons.
    댓글 쓰기
  10. New Nintendo 2DS XL Front Buttons Replacement: 10 단계, 이미지 3개 중 1개 New Nintendo 2DS XL Front Buttons Replacement: 10 단계, 이미지 3개 중 2개 New Nintendo 2DS XL Front Buttons Replacement: 10 단계, 이미지 3개 중 3개
    • Lift off the grey rubber cover on the start and select buttons.
    댓글 쓰기
  11. New Nintendo 2DS XL Front Buttons Replacement: 11 단계, 이미지 3개 중 1개 New Nintendo 2DS XL Front Buttons Replacement: 11 단계, 이미지 3개 중 2개 New Nintendo 2DS XL Front Buttons Replacement: 11 단계, 이미지 3개 중 3개
    • Lift off the grey rubber membrane on the D-pad.
    • Using tweezers, lift the D-pad out.
    댓글 쓰기
  12. New Nintendo 2DS XL Front Buttons Replacement: 12 단계, 이미지 3개 중 1개 New Nintendo 2DS XL Front Buttons Replacement: 12 단계, 이미지 3개 중 2개 New Nintendo 2DS XL Front Buttons Replacement: 12 단계, 이미지 3개 중 3개
    • Lift off the grey rubber membrane covering the home button.
    • Using tweezers, lift out the button.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Tim Newman
회원 가입일: 09/25/17
2,039 평판
안내서 4개를 작성함
Cal Poly, Team S18-G6, Forte Fall 2017 Cal Poly, Team S18-G6, Forte Fall 2017 회원
CPSU-FORTE-F17S18G6
5 회원들
안내서 24개를 작성함
4가이드 댓글
after assembly, pressing ZL causes some kind of an electric short, and the console turns off immediately, help !
mos_boum - 답글 공유
This usually occurs when you break the lower screen's power ribbon cable connector. It is not a ZIF connector and "unlatching" it will break it causing a loose fit. The shoulder button presses against the ribbon cable causing it to shift in the connector resulting in the speakers popping and the device turning off.
Mike - 답글 공유
OK. Lets say I can now change the buttons for replacement purposes only. My question is :where on the earth i can find buttons to replace??????
Robert - 답글 공유
Now there is a full set of keys for 2dsxl. If you can't find it, you can google kasynparts
kasynlife - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 126
지난 30일: 394
전체 시간: 21,242
