주요 콘텐츠로 건너뛰기
NexiGo NS32 Vibration Motor Replacement
Naiza Hall
Naiza Hall3 다른 기여자
최종 수정일 June 19, 2024
6 - 7 분
조정
This is a guide on how to replace the vibration motor from inside the NexiGo NS32. There are 5 specific steps in this guide that describe how to take the vibration motor out of the controller. Be careful not to damage any of the internal components.
필요한 것
도구
더보기...
  1. NexiGo NS32 Vibration Motor Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
    • Orient the controller so that it is face down.
  2. NexiGo NS32 Vibration Motor Replacement: 2 단계, 이미지 2개 중 1개 NexiGo NS32 Vibration Motor Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the eight 9 mm Phillips screws that secure the rear case.
  3. NexiGo NS32 Vibration Motor Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the rear case up and off.
    • You may need to use an opening tool to help release the rear case, but avoid using excessive force so you don't damage the controller.
  4. NexiGo NS32 Vibration Motor Replacement, Vibration Motor: 4 단계, 이미지 3개 중 1개 NexiGo NS32 Vibration Motor Replacement, Vibration Motor: 4 단계, 이미지 3개 중 2개 NexiGo NS32 Vibration Motor Replacement, Vibration Motor: 4 단계, 이미지 3개 중 3개
    • Grip the white vibration motor connections and pull them directly out of their sockets.
  5. NexiGo NS32 Vibration Motor Replacement: 5 단계, 이미지 2개 중 1개 NexiGo NS32 Vibration Motor Replacement: 5 단계, 이미지 2개 중 2개
    • Gently lift out the vibration motors.
    • The vibration motors may be glued in place. If you're having trouble removing them, apply some high-concentration isopropyl alcohol to loosen the adhesive.
결론
작성자
3다른 기여자 명과 함께
Naiza Hall
회원 가입일: 01/29/24
265 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 83
