이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use a SIM card eject tool, to pop out and remove the SIM card tray.
Use an iOpener to loosen the adhesive underneath the small plastic cover at the bottom of the phone.
Insert a knife between the phone and the plastic cover. Pry up the plastic cover until you can insert an opening pick.
Slide the opening pick underneath the plastic cover to cut the adhesive.
Use an iOpener to loosen the adhesive underneath the glass cover at the top of the phone.
Insert a knife between the phone and the glass cover. Pry up the glass cover until you can insert an opening pick.
Slide the opening pick underneath the glass cover and use it to cut the adhesive underneath.
Pry off the glass cover.
Remove the six Phillips #00 screws.
Use tweezers to remove any stickers covering the screw to allow better seating for the driver.
Insert a razor knife between the metal back cover and the front glass to create a gap. Insert an opening pick into the gap and slide it to the top right corner.
Insert a second opening pick and slide it to the top left corner.
Slide the opening picks along the edges to seperate the plastic clips, holding back cover and midframe together.
Remove the rear cover.
Unscrew the Phillips #00 screw.
Use tweezers to remove the metal plate.
Use the flat end of a spudger to disconnect the interconnect cable from the daughterboard.
Use an iOpener to loosen the adhesive under the battery.
이 단계에 사용된 도구:Plastic Cards$2.99-
Insert the flat end of a spudger as deep as the notch and carefully slide along the edge to cut the adhesive…
Use a plastic card to cut the remaining adhesive on the left side underneath the battery.
Remove the two Philipps #000 screws.
Remove the metal plate.
Use the flat end of a spudger to disconnect the display flex cable.
Work an iFlex opening tool between the display and the midframe to create a gap.
Insert an opening pick into the gap and carefully slide it to the top right corner.
Insert a second opening pick and move it to the top left corner.
Slide the opening pick from the top left corner down the left side of the smartphone to the bottom left corner.
Slide the opening pick from the top right around the corner and down along the side to the lower right.
Move it around the corner and towards the charging port to separate the rest of the adhesive.
When all the adhesive is cut, separate the display from the midframe at the top of the phone.
Thread the display flex cable through the gap in the midframe.
Remove the display.
다른 23명이 해당 안내서를 완성하였습니다.
