주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nexus S Motherboard Replacement
필요한 것
  1. Nexus S Motherboard Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
    댓글 쓰기
  2. Nexus S Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the rear panel from the Nexus S.
    댓글 쓰기
  3. Nexus S Motherboard Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
    댓글 쓰기
  4. Nexus S Motherboard Replacement, SIM Card: 4 단계, 이미지 2개 중 1개 Nexus S Motherboard Replacement, SIM Card: 4 단계, 이미지 2개 중 2개
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
    댓글 쓰기
  5. Nexus S Motherboard Replacement, Rear Inner Frame: 5 단계, 이미지 1개 중 1개
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
    댓글 쓰기
  6. Nexus S Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
    댓글 쓰기
  7. Nexus S Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Nexus S Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
    댓글 쓰기
  8. Nexus S Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Nexus S Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
    댓글 쓰기
  9. Nexus S Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
    댓글 쓰기
  10. Nexus S Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Lift and remove the rear inner frame from the Nexus S.
    댓글 쓰기
  11. Nexus S Motherboard Replacement, Motherboard: 11 단계, 이미지 1개 중 1개
    • Disconnect the following cables from their respective sockets on the motherboard:
    • Headphone jack cable
    • Digitizer cable connector
    • Camera/SIM board connector
    댓글 쓰기
  12. Nexus S Motherboard Replacement: 12 단계, 이미지 3개 중 1개 Nexus S Motherboard Replacement: 12 단계, 이미지 3개 중 2개 Nexus S Motherboard Replacement: 12 단계, 이미지 3개 중 3개
    • Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
    • Make sure to pry on the connector and not the socket itself. Prying the socket may cause severe damage.
    • Repeat the procedure for the digitizer and rear camera/SIM board connectors.
    댓글 쓰기
  13. Nexus S Motherboard Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the three Phillips screws securing the motherboard to the front display assembly.
    댓글 쓰기
  14. Nexus S Motherboard Replacement: 14 단계, 이미지 2개 중 1개 Nexus S Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Wedge the plastic opening tool near the bottom right corner of the motherboard and pry upwards to dislodge it from its recess.
    • Lift and remove the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 15명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Walter Galan
710,152 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 68
전체 시간: 14,623
