주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nike SportWatch GPS Unit Replacement
필요한 것
    1. Nike SportWatch GPS Unit Replacement, GPS Unit: 1 단계, 이미지 1개 중 1개
      • Using a size #000 Phillips screwdriver, remove the six 5 mm screws on the back of the device.
      댓글 쓰기
    2. Nike SportWatch GPS Unit Replacement: 2 단계, 이미지 1개 중 1개
      • Then, gently pull the watch band and front screen apart.
      댓글 쓰기
    3. Nike SportWatch GPS Unit Replacement: 3 단계, 이미지 1개 중 1개
      • Using a size #000 Phillips screwdriver, remove the two 2.5 mm screws on the main board.
      댓글 쓰기
    4. Nike SportWatch GPS Unit Replacement: 4 단계, 이미지 1개 중 1개
      • Carefully, use the blue plastic opening tool to pry the main board out of the front panel.
      • Use extreme care when handling the ribbon cable. Avoid twisting or pulling it, as it is delicate and cannot be removed or replaced if damaged.
      댓글 쓰기
    5. Nike SportWatch GPS Unit Replacement: 5 단계, 이미지 1개 중 1개
      • Using the spudger, remove the orange tape that covers the wire for the GPS.
      댓글 쓰기
    6. Nike SportWatch GPS Unit Replacement: 6 단계, 이미지 1개 중 1개
      • Using the soldering iron, break the wire connecting the GPS to the main board at the connector.
      • When desoldering the GPS wire, set the soldering iron to a moderate heat level (around 350°C/662°F). To prevent damage, avoid prolonged contact with the board. For detailed instructions, refer to the iFixit soldering guide.
      댓글 쓰기
    7. Nike SportWatch GPS Unit Replacement: 7 단계, 이미지 1개 중 1개
      • To reassemble, follow the steps in reverse order. Ensure all connections are secure, screws are tightened evenly, and no ribbon cables are pinched. Once complete, test the watch by powering it on and verifying GPS functionality in an open area.
      댓글 쓰기
    8. Nike SportWatch GPS Unit Replacement: 8 단계, 이미지 1개 중 1개
      • After reassembly, power on the watch and perform a GPS test outdoors in a clear area. Wait for the watch to acquire a signal to confirm the successful replacement.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Ian Eichorn
회원 가입일: 10/22/15
696 평판
안내서 4개를 작성함
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G8
3 회원들
안내서 5개를 작성함
3가이드 댓글
which GPS unit is it?
charles - 답글 공유
what gps unit is it?
charles - 답글 공유
I would also like to know what GPS unit that is and if it is possible to find a replacement or a compatible unit?
avs4820 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 13
지난 30일: 41
전체 시간: 2,334
