주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon D3100 Motherboard Replacement
필요한 것
  1. Nikon D3100 Motherboard Replacement, LCD Screen: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver for all of the screws.
    • Remove two of the 4mm screws indicated by the circles on the bottom side of the camera.
    댓글 쓰기
  2. Nikon D3100 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Nikon D3100 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove four of the 3mm screws around the eye piece located on the top of the back panel, including the screw hidden behind the auto focus label.
    • Remove the 3mm screw behind the rubber grip on the top right of the back panel.
    댓글 쓰기
  3. Nikon D3100 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Peel back the rubber grip on the right side of the camera using a spudger.
    • You may need a heating pad to melt the glue holding the rubber grip to the camera. If using the heating pad, use caution and handle carefully.
    • Remove two of the 5mm screws under the rubber grip.
    댓글 쓰기
  4. Nikon D3100 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove two of the 4mm screws on the left side of the camera.
    댓글 쓰기
  5. Nikon D3100 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Nikon D3100 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Starting from the top, gently lift the back panel of the camera off. Slowly separate the back panel from the main body of the camera.
    • Be careful not to pull the panel out too fast or the ribbon may be damaged.
    • Carefully remove the ribbon using a spudger to lift up the connector and then use tweezers to pull out the ribbon.
    • Separate the back panel from the main body of the camera.
    댓글 쓰기
  6. Nikon D3100 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Be careful when separating the metal plate from the back panel because the speaker wire is connected to the metal plate. It can easily be torn if caution is not taken.
    • Remove nine of the 3mm screws connecting the metal plate to the plastic panel.
    댓글 쓰기
  7. Nikon D3100 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the tape covering the ribbons. Be careful not to break the tape.
    댓글 쓰기
  8. Nikon D3100 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the two ribbons connecting the LCD screen to the metal plate using the same method from Step 5.
    댓글 쓰기
  9. Nikon D3100 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the old LCD screen from metal plate.
    댓글 쓰기
  10. Nikon D3100 Motherboard Replacement, Motherboard: 10 단계, 이미지 2개 중 1개 Nikon D3100 Motherboard Replacement, Motherboard: 10 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to gently lift the yellow tape from the back of the camera.
    댓글 쓰기
  11. Nikon D3100 Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Use a plastic spudger to remove the 6 ribbons.
    • Be careful not to tear the ribbons.
    댓글 쓰기
  12. Nikon D3100 Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Nikon D3100 Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the plug located on the top-right side of the camera.
    • Remove the plug located on the top-left side of the camera.
    댓글 쓰기
  13. Nikon D3100 Motherboard Replacement: 13 단계, 이미지 1개 중 1개
    • Use a Philips #00 Screwdriver to remove the five 3 mm screws marked in the image.
    댓글 쓰기
  14. Nikon D3100 Motherboard Replacement: 14 단계, 이미지 2개 중 1개 Nikon D3100 Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Gently pull out the side wall of the camera so that the motherboard comes out easier.
    • Do not pull too hard or you will risk breaking the plastic.
    댓글 쓰기
  15. Nikon D3100 Motherboard Replacement: 15 단계, 이미지 1개 중 1개
    • Be careful while lifting the motherboard because there is one more ribbon attached.
    • Gently lift the motherboard to separate it from the back of the camera.
    • Use a plastic spudger to detach the ribbon.
    댓글 쓰기
  16. Nikon D3100 Motherboard Replacement: 16 단계, 이미지 1개 중 1개
    • Replace the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Jet Mejia
회원 가입일: 09/26/16
686 평판
안내서 3개를 작성함
USF Tampa, Team 14-1, Eyestone Fall 2016 USF Tampa, Team 14-1, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S14G1
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 22
지난 30일: 102
전체 시간: 6,658
