주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon D80 Main Board Replacement
필요한 것
    1. Nikon D80 Main Board Replacement, Main Board: 1 단계, 이미지 2개 중 1개 Nikon D80 Main Board Replacement, Main Board: 1 단계, 이미지 2개 중 2개
      • Using a Phillips #00 screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover.
      댓글 쓰기
    2. Nikon D80 Main Board Replacement: 2 단계, 이미지 3개 중 1개 Nikon D80 Main Board Replacement: 2 단계, 이미지 3개 중 2개 Nikon D80 Main Board Replacement: 2 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
      • Pull the orange connector cable out of the zero force insertion connector using the tweezers.
      • Remove the back cover.
      댓글 쓰기
    3. Nikon D80 Main Board Replacement: 3 단계, 이미지 3개 중 1개 Nikon D80 Main Board Replacement: 3 단계, 이미지 3개 중 2개 Nikon D80 Main Board Replacement: 3 단계, 이미지 3개 중 3개
      • Use a Phillips #00 screwdriver to remove the six 3.7 mm screws.
      • Remove the back plate that covers the main board.
      댓글 쓰기
    4. Nikon D80 Main Board Replacement: 4 단계, 이미지 2개 중 1개 Nikon D80 Main Board Replacement: 4 단계, 이미지 2개 중 2개
      • Use a Phillips #00 screwdriver to unscrew the 2.3 mm screw.
      댓글 쓰기
    5. Nikon D80 Main Board Replacement: 5 단계, 이미지 1개 중 1개
      • Use tweezers to gently flip the small locking flaps of the zero force insertion connectors up.
      • Pull the bottom orange connector cable out of the zero force insertion connector using the tweezers.
      • Pull the top orange connector cable out of the zero force insertion connector using the tweezers.
      • Remove the ribbon cables by gently pulling them away from the no-fuss ribbon cable connectors.
      • Disconnect the main board from the two ports on the left by pulling the main board to the right.
      댓글 쓰기
    6. Nikon D80 Main Board Replacement: 6 단계, 이미지 3개 중 1개 Nikon D80 Main Board Replacement: 6 단계, 이미지 3개 중 2개 Nikon D80 Main Board Replacement: 6 단계, 이미지 3개 중 3개
      • Using the soldering iron, disconnect the four wires soldered to the main board.
      • For more information on how to solder and desolder connections, please visit this guide.
      • Be careful when using the hot soldering iron. Move the ribbon cable out of the way as well; it is easy to burn it or yourself when using the iron.
      • Remove the main board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Sara Martin
회원 가입일: 10/09/17
610 평판
안내서 4개를 작성함
USF Tampa, Team S1-G1, Leahy Fall 2017 USF Tampa, Team S1-G1, Leahy Fall 2017 회원
USFT-LEAHY-F17S1G1
4 회원들
안내서 45개를 작성함
1가이드 댓글
Is there a Nikon repair forum that might provide more detailed information?
this is the clearest instructions so far but I’m sure there are diagnostic codes for more precise troubleshooting
Mermaid - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 39
전체 시간: 3,367
