주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ninja NJ600 Button Replacement
필요한 것
    1. Ninja NJ600 Button Replacement, Blender Base Cover: 1 단계, 이미지 2개 중 1개 Ninja NJ600 Button Replacement, Blender Base Cover: 1 단계, 이미지 2개 중 2개
      • Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
      댓글 쓰기
    2. Ninja NJ600 Button Replacement: 2 단계, 이미지 2개 중 1개 Ninja NJ600 Button Replacement: 2 단계, 이미지 2개 중 2개
      • Without removing any screws, you can pull the 2nd layer free from the base. Do this now and set it down gently next to the base.
      • The power cord runs through a hole in the side of this layer. Squeeze the cord and pull it through the hole to separate the layer from the cord.
      댓글 쓰기
    3. Ninja NJ600 Button Replacement: 3 단계, 이미지 3개 중 1개 Ninja NJ600 Button Replacement: 3 단계, 이미지 3개 중 2개 Ninja NJ600 Button Replacement: 3 단계, 이미지 3개 중 3개
      • Using the Phillips #2 screwdriver, remove these six screws (13mm long, 6mm head diameter). Then carefully remove this layer, and rest it next to the blender base.
      • Be careful not to damage the two wires that are keeping this third layer attached to the base.
      댓글 쓰기
    1. Ninja NJ600 Button Replacement, Circuit Board: 4 단계, 이미지 1개 중 1개
      • Remove these four screws (10mm long, 5mm head diameter) using a Phillips #2 screwdriver.
      • Be careful not to scratch the circuit board with the screwdriver.
      댓글 쓰기
    2. Ninja NJ600 Button Replacement: 5 단계, 이미지 1개 중 1개
      • Using a pair of scissors or wire cutters, cut the zip tie holding these wires.
      • This will give the circuit board more range of motion.
      댓글 쓰기
    3. Ninja NJ600 Button Replacement: 6 단계, 이미지 3개 중 1개 Ninja NJ600 Button Replacement: 6 단계, 이미지 3개 중 2개 Ninja NJ600 Button Replacement: 6 단계, 이미지 3개 중 3개
      • Desolder the five wires from the solder pads shown.
      • If you do not know how to do this, iFixit has a guide describing the process.
      • Before you begin to desolder these wires, flip the board over to confirm that you are about to desolder the correct component.
      • Soldering iron is very hot, use caution when handling
      댓글 쓰기
    4. Ninja NJ600 Button Replacement: 7 단계, 이미지 1개 중 1개
      • After the wires have cooled enough to touch, carefully slide the circuit board free of the wires.
      • NOTE: keep track of which pad each wire was soldered to. This is important for your blender to function.
      댓글 쓰기
    1. Ninja NJ600 Button Replacement, Button: 8 단계, 이미지 2개 중 1개 Ninja NJ600 Button Replacement, Button: 8 단계, 이미지 2개 중 2개
      • After removing the circuit board from your device, locate which button you wish to replace.
      • On the opposite side of the circuit board from the button, there are four solder pads with the designation "SW" followed by a number.
      댓글 쓰기
    2. Ninja NJ600 Button Replacement: 9 단계, 이미지 1개 중 1개
      • Desolder these four solder pads.
      • These pads are small, so take care to not damage the circuit board.
      • NOTE: the orientation of the buttons is important. Make sure you place the new button in the correct orientation.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order, except soldering when you desoldered previously.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Kody D
회원 가입일: 04/01/15
573 평판
안내서 3개를 작성함
Cal Poly, Team 24-2, Lancaster Spring 2015 Cal Poly, Team 24-2, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G2
4 회원들
안내서 12개를 작성함
1가이드 댓글
ZNR1 please help in value
Kalpesh Patel - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 24
전체 시간: 1,645
