주요 콘텐츠로 건너뛰기
Nintendo DS Upper LCD Screen Replacement
필요한 것
  1. Nintendo DS Upper LCD Screen Replacement, Battery: 1 단계, 이미지 3개 중 1개 Nintendo DS Upper LCD Screen Replacement, Battery: 1 단계, 이미지 3개 중 2개 Nintendo DS Upper LCD Screen Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
  2. Nintendo DS Upper LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
  3. Nintendo DS Upper LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery from the Nintendo DS.
  4. Nintendo DS Upper LCD Screen Replacement, Back Panel: 4 단계, 이미지 1개 중 1개
    • Remove the seven 6.4mm Y00 screws located on the back.
    • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
  5. Nintendo DS Upper LCD Screen Replacement: 5 단계, 이미지 3개 중 1개 Nintendo DS Upper LCD Screen Replacement: 5 단계, 이미지 3개 중 2개 Nintendo DS Upper LCD Screen Replacement: 5 단계, 이미지 3개 중 3개
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
  6. Nintendo DS Upper LCD Screen Replacement, Motherboard replacement.: 6 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
    • Be careful NOT to slip with the screwdriver, you can damage the circuit board!
  7. Nintendo DS Upper LCD Screen Replacement: 7 단계, 이미지 3개 중 1개 Nintendo DS Upper LCD Screen Replacement: 7 단계, 이미지 3개 중 2개 Nintendo DS Upper LCD Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Unlock the two large ribbon cables by moving the black clip up.
    • Carefully pull the ribbon cables down and out with your fingers.
    • Do not use pliers to pull the cables, as they can be damaged easily.
  8. Nintendo DS Upper LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 Nintendo DS Upper LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Locate the two small ribbon cables, beneath the rightmost large ribbon cable.
    • Slide the locks for the small ribbon cables down to the side, and remove the cables.
    • It may be useful to use tweezers to remove the small ribbon cables.
    • Be careful not to damage the delicate ribbon cables.
  9. Nintendo DS Upper LCD Screen Replacement: 9 단계, 이미지 2개 중 1개 Nintendo DS Upper LCD Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Locate the Wifi antenna pigtail connector.
    • Remove the antenna by grasping it at the head with tweezers. Using a slight rocking motion, pull up to dislodge the connector.
  10. Nintendo DS Upper LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Feed the ribbon cables through the opening on the board.
    • Pull up and remove the circuit board, and set it aside.
  11. Nintendo DS Upper LCD Screen Replacement, Remove the screw covers: 11 단계, 이미지 3개 중 1개 Nintendo DS Upper LCD Screen Replacement, Remove the screw covers: 11 단계, 이미지 3개 중 2개 Nintendo DS Upper LCD Screen Replacement, Remove the screw covers: 11 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a flathead screwdriver, tweezers, a toothpick or dental tool to remove rubber covers on screen.
    • While doing so, please be sure to remove the rubber screw covers carefully. If they rip or get damaged, you may have to buy new ones. These are NOT required to seal up the console, but for aesthetic purposes and for keeping dirt and water out, you should (re)install the rubber screw covers.
    • Remove the four screws using a Phillips #00 screwdriver.
  12. Nintendo DS Upper LCD Screen Replacement, Remove the front cover: 12 단계, 이미지 3개 중 1개 Nintendo DS Upper LCD Screen Replacement, Remove the front cover: 12 단계, 이미지 3개 중 2개 Nintendo DS Upper LCD Screen Replacement, Remove the front cover: 12 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, pry the edges of the plastic case apart at the seam.
  13. Nintendo DS Upper LCD Screen Replacement, Separate the top cover: 13 단계, 이미지 3개 중 1개 Nintendo DS Upper LCD Screen Replacement, Separate the top cover: 13 단계, 이미지 3개 중 2개 Nintendo DS Upper LCD Screen Replacement, Separate the top cover: 13 단계, 이미지 3개 중 3개
    • Separate the top cover from the body.
    • Using a Phillips #00 screwdriver, remove the screw holding the hinge cover in place.
    • Remove the hinge cover and set it aside.
  14. Nintendo DS Upper LCD Screen Replacement: 14 단계, 이미지 2개 중 1개 Nintendo DS Upper LCD Screen Replacement: 14 단계, 이미지 2개 중 2개
    • Feed the ribbon cables and the Wifi pigtail cable through the opening in the hinge cover.
    • Remove the yellow spacer, and set aside.
  15. Nintendo DS Upper LCD Screen Replacement, Remove the speaker boards: 15 단계, 이미지 2개 중 1개 Nintendo DS Upper LCD Screen Replacement, Remove the speaker boards: 15 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the two screws holding down the speaker circuit boards.
    • Remove the two small circuit boards and set aside.
    • Be careful of the small red and black wires connecting the two circuit boards not to break them.
  16. Nintendo DS Upper LCD Screen Replacement: 16 단계, 이미지 3개 중 1개 Nintendo DS Upper LCD Screen Replacement: 16 단계, 이미지 3개 중 2개 Nintendo DS Upper LCD Screen Replacement: 16 단계, 이미지 3개 중 3개
    • Move the black lock on the two large ribbon cables up with a pry tool, and gently pull out the two ribbon cables.
    • For the small ribbon cable, pull the lock downwards.
    • Gently pull out the small ribbon cable from the connector.
    • Set the two small circuit boards aside
    • Be careful not to damage the two delicate ribbon cables when removing them from the DS.
  17. Nintendo DS Upper LCD Screen Replacement, Remove the screen: 17 단계, 이미지 2개 중 1개 Nintendo DS Upper LCD Screen Replacement, Remove the screen: 17 단계, 이미지 2개 중 2개
    • Using a pry tool, gently lift the top screen out of the shell.
    • Set the top screen aside
결론
다른 48명이 해당 안내서를 완성하였습니다.
작성자
20다른 기여자 명과 함께
dnguye26
회원 가입일: 10/28/09
740 평판
안내서 4개를 작성함
Cal Poly, Team 18-3, Maness Fall 2009 Cal Poly, Team 18-3, Maness Fall 2009 회원
CPSU-MANESS-F09S18G3
4 회원들
안내서 31개를 작성함
13가이드 댓글
Unlike the DS Lite and later models, there is no reason to take apart the bottom portion of the original DS in order to remove the top screen. The first ten steps of this guide could be skipped.
PohTayToez - 답글
Thanks great advice
truenhete TrueNhero -
Can a ds lite screen be used to repair a ds??
David Moore - 답글
Nope, Nintendo engineered the Lite as a refinement of the original. Therefore almost every component is different! Likely to become cheaper to manufacture.
Del Riordan -
Can a ds lite screen be used to repair a ds one?? Lots of ds lite screens about......
David Moore - 답글
댓글 쓰기
조회 통계:
지난 24시간: 37
지난 7일: 257
지난 30일: 1,269
전체 시간: 129,340
