Nintendo DSi XL Volume Buttons Replacement
Give your DSi XL and audio edge by replacing the volume buttons.
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Remove the four rubber screw covers on the lower case by prying them up with a push pin.
On the inside of the battery compartment, use the tip of a spudger to detach the metal latch securing the volume control switch in place.
이 단계에 사용된 도구:Tweezers$4.99
While pushing the volume buttons through their holes in the lower case, remove the buttons and their silicone pads with a pair of tweezers.
Remove the buttons from the silicone pad.
다른 한 분이 해당 안내서를 완성하였습니다.
