주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Entertainment System Controller Maintenance
필요한 것
  1. Nintendo Entertainment System Controller Maintenance, Nintendo Entertainment System Controller Maintenance: 1 단계, 이미지 1개 중 1개
    • Unscrew the six 13 mm screws with the Philips screwdriver.
    댓글 쓰기
  2. Nintendo Entertainment System Controller Maintenance: 2 단계, 이미지 1개 중 1개
    • Lift the controller back plate straight off of the controller then set aside.
    댓글 쓰기
  3. Nintendo Entertainment System Controller Maintenance: 3 단계, 이미지 1개 중 1개
    • Unwind the cable from plastic poles.
    댓글 쓰기
  4. Nintendo Entertainment System Controller Maintenance: 4 단계, 이미지 1개 중 1개
    • Gently remove the circuit board from the controller face. Use a non marring object to lever up board if it is stuck.
    댓글 쓰기
  5. Nintendo Entertainment System Controller Maintenance: 5 단계, 이미지 1개 중 1개
    • Remove the indicated rubber pads.
    댓글 쓰기
  6. Nintendo Entertainment System Controller Maintenance: 6 단계, 이미지 1개 중 1개
    • Remove all plastic buttons. Clean the buttons and controller with soap and water.
    댓글 쓰기
  7. Nintendo Entertainment System Controller Maintenance: 7 단계, 이미지 1개 중 1개
    • Inspect each rubber pad for tears or cracks and making note of any tears.
    댓글 쓰기
  8. Nintendo Entertainment System Controller Maintenance: 8 단계, 이미지 1개 중 1개
    • Clean all pads with rubbing alcohol; focus on cleaning the black conductive circles on the underside of the pads.
    댓글 쓰기
  9. Nintendo Entertainment System Controller Maintenance: 9 단계, 이미지 1개 중 1개
    • Once clean, apply thin layers of rubber cement to any deformation. Allow cement to dry and apply multiple layers as needed. Do not over apply rubber cement as it can cause the pads to warp as it dries.
    댓글 쓰기
  10. Nintendo Entertainment System Controller Maintenance: 10 단계, 이미지 1개 중 1개
    • Inspect all solder points for loose connections.
    댓글 쓰기
  11. Nintendo Entertainment System Controller Maintenance: 11 단계, 이미지 1개 중 1개
    • Clean the input contacts with 91% Isopropyl Alcohol on a Q-tip
    댓글 쓰기
  12. Nintendo Entertainment System Controller Maintenance: 12 단계, 이미지 1개 중 1개
    • Read the iFixit soldering guide and do not attempt this step if you are not confidant in your ability to do so safely.
    • Ensure that all 91% isopropyl alcohol has evaporated. If necessary perform any soldering away from the area in which you cleaned the controller.
    • Re-solder any loose wires on the circuit board.
    댓글 쓰기
  13. Nintendo Entertainment System Controller Maintenance: 13 단계, 이미지 1개 중 1개
    • Allow any recently soldered points to cool back to room temperature before performing this step.
    • Glue the cord onto the circuit board to prevent future loosening of the wires.
    • Leave slack on both sides and allow glue to harden.
    댓글 쓰기
  14. Nintendo Entertainment System Controller Maintenance: 14 단계, 이미지 1개 중 1개
    • Reverse steps from 6 through to 2 to reassemble controller.
    • Before replacing screws make sure the controller back fits tightly to the controller face.
    • If needed trim excess glue from around the cord to ensure a good fit.
    댓글 쓰기
  15. Nintendo Entertainment System Controller Maintenance: 15 단계, 이미지 1개 중 1개
    • Plug in your repaired controller and try all buttons and actions to test controller function and responsiveness
    댓글 쓰기
결론
Thank you for using our step by step controller guide. Enjoy your NES games!
If the controller isn’t working after this guide, re-check the soldering points, and redo as necessary. If this still doesn’t fix the controller you may have to get a new wire.
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Andrew Churchill
회원 가입일: 09/22/15
245 평판
안내서 1개를 작성함
Colorado Springs, Team 1-6, Mcmichael Fall 2015 Colorado Springs, Team 1-6, Mcmichael Fall 2015 회원
UCCS-MCMICHAEL-F15S1G6
2 회원들
안내서 2개를 작성함
1가이드 댓글
Hi There,
Just wondering if you knew “where” I could purchase a special set of silicone buttons for a wireless Nintendo NES controller? The buttons are sticking and when I remove the cover, the silicone buttons were stripped and no longer functional. I know how to replace all of the parts - just not sure where I can actually find the part that I need.
I am not sure if you know what the “NES wireless controller” looks like “internally” but it has 4 buttons together - not just 2 like the original NES controller. The silicone button assembly looks very similar to the silicone button assembly of the “controller buttons” portion (or the arrows portion that actually allows you to “move” when playing a game.
Any assistance you could provide for me to find the right part to fix my son’s controller would be GREATLY APPRECIATED !!
Thank you
Jeff
Jeff L - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 96
전체 시간: 12,546
