주요 콘텐츠로 건너뛰기
Nintendo Game Boy Advance SP Back Cover Replacement
필요한 것
  1. Nintendo Game Boy Advance SP Back Cover Replacement, Battery: 1 단계, 이미지 1/1
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Nintendo Game Boy Advance SP Back Cover Replacement: 2 단계, 이미지 1/1
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Back Cover Replacement: 3 단계, 이미지 1/1
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
  4. Nintendo Game Boy Advance SP Back Cover Replacement, Back Cover: 4 단계, 이미지 1/2 Nintendo Game Boy Advance SP Back Cover Replacement, Back Cover: 4 단계, 이미지 2/2
    • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
    • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  5. Nintendo Game Boy Advance SP Back Cover Replacement: 5 단계, 이미지 1/1
    • Lift the back cover off of the device.
    • Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
    • Look out for the power switch that can fall out when taking the back cover off.
결론
다른 18명이 해당 안내서를 완성하였습니다.
Rocco Lattanzio
회원 가입일: 01/11/13
893 평판
안내서 2개 작성하였습니다
Cal Poly, Team 17-22, Forte Winter 2013 Cal Poly, Team 17-22, Forte Winter 2013 회원
CPSU-FORTE-W13S17G22
4 회원들
안내서 38개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 31
7일 전: 130
30일 전: 529
전체 시간: 25,937
