주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Game Boy Advance SP Buttons Replacement
필요한 것
  1. Nintendo Game Boy Advance SP Buttons Replacement, Prepare your Game Boy for disassembly: 1 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Buttons Replacement, Prepare your Game Boy for disassembly: 1 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Buttons Replacement, Prepare your Game Boy for disassembly: 1 단계, 이미지 3개 중 3개
    • Slide the power switch to the OFF position and unplug any cables.
    • If you have a game cartridge in, remove it.
    댓글 쓰기
  2. Nintendo Game Boy Advance SP Buttons Replacement, Remove the battery cover: 2 단계, 이미지 2개 중 1개 Nintendo Game Boy Advance SP Buttons Replacement, Remove the battery cover: 2 단계, 이미지 2개 중 2개
    • Use a JIS 00 screwdriver to loosen the captive screw securing the battery cover.
    • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
    댓글 쓰기
  3. Nintendo Game Boy Advance SP Buttons Replacement: 3 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Buttons Replacement: 3 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Buttons Replacement: 3 단계, 이미지 3개 중 3개
    • Lift the edge of the cover near the screw and remove the cover.
    • During reassembly, hook the tabs on the bottom edge of the cover into their slots and lay the cover into place.
    댓글 쓰기
  4. Nintendo Game Boy Advance SP Buttons Replacement, Remove the battery: 4 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Buttons Replacement, Remove the battery: 4 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Buttons Replacement, Remove the battery: 4 단계, 이미지 3개 중 3개
    • Use your finger to lift the battery by the tab on its left edge, then remove it.
    • During reassembly:
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
    • Your replacement battery may come with a plastic enclosure that slides over the battery.
    • Insert the edge of the battery with contacts at a slight downward angle—aligning the contacts with their prongs in the recess—and press the battery into place.
    댓글 쓰기
  5. Nintendo Game Boy Advance SP Buttons Replacement, Remove the bottom shell: 5 단계, 이미지 2개 중 1개 Nintendo Game Boy Advance SP Buttons Replacement, Remove the bottom shell: 5 단계, 이미지 2개 중 2개
    • Use a tri‑point Y0 screwdriver to remove the six screws securing the bottom shell:
    • Four 6.3 mm‑long recessed screws
    • Two 4.6 mm‑long screws
    댓글 쓰기
  6. Nintendo Game Boy Advance SP Buttons Replacement: 6 단계, 이미지 2개 중 1개 Nintendo Game Boy Advance SP Buttons Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the bottom shell straight up and remove it.
    댓글 쓰기
  7. Nintendo Game Boy Advance SP Buttons Replacement, Unclip the shoulder buttons: 7 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Buttons Replacement, Unclip the shoulder buttons: 7 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Buttons Replacement, Unclip the shoulder buttons: 7 단계, 이미지 3개 중 3개
    • The shoulder buttons are located on the rear shell. They're made up of three parts—the plastic cover, a hinge pin, and a small spring.
    • Use the point of a spudger to push the spring arm out from under its clip.
    댓글 쓰기
  8. Nintendo Game Boy Advance SP Buttons Replacement, Remove the shoulder buttons: 8 단계, 이미지 2개 중 1개 Nintendo Game Boy Advance SP Buttons Replacement, Remove the shoulder buttons: 8 단계, 이미지 2개 중 2개
    • The button’s three parts will likely fall out during removal—don’t worry, just set them aside for reassembly.
    • Lift the shoulder button straight up and off its hinge pin to remove it.
    • Repeat the process to remove the other shoulder button.
    • During reassembly, follow this guide to install the shoulder buttons.
    댓글 쓰기
  9. Nintendo Game Boy Advance SP Buttons Replacement, Remove the power switch cover: 9 단계, 이미지 2개 중 1개 Nintendo Game Boy Advance SP Buttons Replacement, Remove the power switch cover: 9 단계, 이미지 2개 중 2개
    • Use your fingers to lift and remove the power switch cover.
    • Use your fingers to put the power switch cover (notched side up) into place so the cutout goes around the actual switch.
    • Gently slide the cover back and forth to make sure it's positioned properly and moving the switch.
    • If the switch isn't properly in its cutout, you won't be able to power on your Game Boy.
    댓글 쓰기
  10. Nintendo Game Boy Advance SP Buttons Replacement, Remove the motherboard screws: 10 단계, 이미지 2개 중 1개 Nintendo Game Boy Advance SP Buttons Replacement, Remove the motherboard screws: 10 단계, 이미지 2개 중 2개
    • Use a JIS 00 screwdriver to remove the three 4.1 mm‑long screws securing the motherboard.
    댓글 쓰기
  11. Nintendo Game Boy Advance SP Buttons Replacement, Prop up the motherboard: 11 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Buttons Replacement, Prop up the motherboard: 11 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Buttons Replacement, Prop up the motherboard: 11 단계, 이미지 3개 중 3개
    • Place a sturdy object such as a stack of books or tool case along the edge of your Game Boy with the hinges.
    • Use your fingers to gently flip the motherboard over the hinges and prop it up.
    댓글 쓰기
  12. Nintendo Game Boy Advance SP Buttons Replacement, Remove the silicone pads: 12 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Buttons Replacement, Remove the silicone pads: 12 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Buttons Replacement, Remove the silicone pads: 12 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to remove the four silicone pads covering the buttons (A and B, D‑pad, brightness, and Start/Select).
    • If any of the pads are missing, they may be stuck to their corresponding spot on the motherboard.
    댓글 쓰기
  13. Nintendo Game Boy Advance SP Buttons Replacement, Remove the buttons: 13 단계, 이미지 3개 중 1개 Nintendo Game Boy Advance SP Buttons Replacement, Remove the buttons: 13 단계, 이미지 3개 중 2개 Nintendo Game Boy Advance SP Buttons Replacement, Remove the buttons: 13 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to remove the buttons (A and B, D‑pad, brightness, and Start/Select).
    • When re‑inserting the action buttons, note that each one is keyed specifically for its recess and proper orientation.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 15명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
195,148 평판
안내서 1,243개를 작성함
5가이드 댓글
Hi,
How do I fix my SP Brighter when A and B buttons are simultaneously pressed, the system turns off? Please Help! Thank you in advance!
Jikan - 답글 공유
there is most likely a crack in the mother board or the battery has too much pressure placed onto it
you can fix this by changing the position of the battery and putting something to stop it from moving around so it fits tightly
Taahaco 2005 - 답글 공유
HI there! My problem is that I have to press the button A harder for the action to be registered, how can I fix that?
アラン - 답글 공유
The L and R buttons done work, they go in perfectly fine but would it be the 2 buttons under them that aren't working? If so then how would I remove and replace them safely
Topi2756 - 답글 공유
The buttons L and R don't work, they go in fine so I'm thinking that it's the buttons on the inside that are damaged. If that is the case then how would I remove and replace them safely?
Topi2756 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 93
지난 30일: 348
전체 시간: 30,583
