주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo GameCube Controller Joystick Replacement
필요한 것
  1. Nintendo GameCube Controller Joystick Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
    댓글 쓰기
  2. Nintendo GameCube Controller Joystick Replacement: 2 단계, 이미지 1개 중 1개
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    댓글 쓰기
  3. Nintendo GameCube Controller Joystick Replacement, Z Button: 3 단계, 이미지 2개 중 1개 Nintendo GameCube Controller Joystick Replacement, Z Button: 3 단계, 이미지 2개 중 2개
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    댓글 쓰기
  4. Nintendo GameCube Controller Joystick Replacement, Circuit Board: 4 단계, 이미지 1개 중 1개
    • Carefully unhook the cable that is looped around the peg.
    댓글 쓰기
  5. Nintendo GameCube Controller Joystick Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
    댓글 쓰기
  6. Nintendo GameCube Controller Joystick Replacement, Joystick: 6 단계, 이미지 2개 중 1개 Nintendo GameCube Controller Joystick Replacement, Joystick: 6 단계, 이미지 2개 중 2개
    • Grab the base of the grey cover and pull it off.
    • During reassembly, make sure the slots inside the joy stick line up so they can fit back together.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 32명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Sean Michel
회원 가입일: 01/14/13
2,750 평판
안내서 8개를 작성함
Cal Poly, Team 19-44, Regan Winter 2013 Cal Poly, Team 19-44, Regan Winter 2013 회원
CPSU-REGAN-W13S19G44
4 회원들
안내서 34개를 작성함
13가이드 댓글
Great guide, but I'm looking to buy replacement joysticks and I can't find them anywhere. Where would I find those?
Joe Freedman - 답글 공유
When I removed the joystick it would come off. The plastic was stuck too hard to the joystick so I accidentally broke it in half. Is there anyway to glue it back together?
Mattias Wirsenius - 답글 공유
@Tyler Lovejoy - That's already part of the controller.
@Joe Freedman - Try Amazon.com
@Mattias Wirsenius - At this point it would be best to buy a new controller.
builderman1q2w3e4r - 답글 공유
This guide is quite unhelpful; it tells you how to remove the stick but not how to repair it. My controller's joystick has sunken into the controller and stays slightly tilted if i move it to the right. Yet when I go to the "rogue joystick" portion of the troubleshooting guide, it tells me to repair the joystick if it's not correctly attached to the motherboard. Seriously, there needs to be a more in-depth guide if such repairs are possible.
J DC - 답글 공유
without taking the controller completely apart, pull the joystick straight up with your hand
McRedstoneYT - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 24
지난 7일: 115
지난 30일: 500
전체 시간: 110,120
