주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo NES Advantage Joystick Spring Replacement
필요한 것
  1. Nintendo NES Advantage Joystick Spring Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Remove the four sticky pads from the bottom of the device.
    • If the pads are stuck, use a spudger to remove them.
    댓글 쓰기
  2. Nintendo NES Advantage Joystick Spring Replacement: 2 단계, 이미지 2개 중 1개 Nintendo NES Advantage Joystick Spring Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the six 8 mm screws from the bottom of the device with a Phillips #0 screwdriver.
    • Use your hands to pull the back panel away from the controller.
    댓글 쓰기
  3. Nintendo NES Advantage Joystick Spring Replacement, Joystick Panel: 3 단계, 이미지 1개 중 1개
    • Remove the four 12 mm screws from the small square panel on the right with a Phillips #0 screwdriver.
    • While removing the last (fourth) screw, apply downward pressure on the panel. This will make it easier to remove the last screw because of the joystick spring on the other side of this panel.
    댓글 쓰기
  4. Nintendo NES Advantage Joystick Spring Replacement: 4 단계, 이미지 2개 중 1개 Nintendo NES Advantage Joystick Spring Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the small square panel.
    • This panel is connected with wires to the main circuit board. To replace the joystick panel, you will need to desolder the wires. To learn more about soldering, refer to our 연결부 납땜 및 납제거 방법 guide.
    댓글 쓰기
  5. Nintendo NES Advantage Joystick Spring Replacement, Joystick: 5 단계, 이미지 2개 중 1개 Nintendo NES Advantage Joystick Spring Replacement, Joystick: 5 단계, 이미지 2개 중 2개
    • Using your hands, unscrew the ball on top of the joystick.
    댓글 쓰기
  6. Nintendo NES Advantage Joystick Spring Replacement: 6 단계, 이미지 1개 중 1개
    • Pull the joystick through the back of the NES Advantage Gamepad.
    댓글 쓰기
  7. Nintendo NES Advantage Joystick Spring Replacement, Joystick Spring: 7 단계, 이미지 3개 중 1개 Nintendo NES Advantage Joystick Spring Replacement, Joystick Spring: 7 단계, 이미지 3개 중 2개 Nintendo NES Advantage Joystick Spring Replacement, Joystick Spring: 7 단계, 이미지 3개 중 3개
    • Using your fingers, pull the spring up and off.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Danielle Guthrie
회원 가입일: 09/06/22
97 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 23
전체 시간: 581
