주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo WaveBird Wireless Controller C-Stick Replacement
필요한 것
  1. Nintendo WaveBird Wireless Controller C-Stick Replacement, Batteries: 1 단계, 이미지 2개 중 1개 Nintendo WaveBird Wireless Controller C-Stick Replacement, Batteries: 1 단계, 이미지 2개 중 2개
    • Pull down on the battery cover release lever and pull back to remove the cover.
    댓글 쓰기
  2. Nintendo WaveBird Wireless Controller C-Stick Replacement: 2 단계, 이미지 1개 중 1개
    • Remove both batteries from the device.
    댓글 쓰기
  3. Nintendo WaveBird Wireless Controller C-Stick Replacement, Front Panel: 3 단계, 이미지 2개 중 1개 Nintendo WaveBird Wireless Controller C-Stick Replacement, Front Panel: 3 단계, 이미지 2개 중 2개
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
    댓글 쓰기
  4. Nintendo WaveBird Wireless Controller C-Stick Replacement: 4 단계, 이미지 2개 중 1개 Nintendo WaveBird Wireless Controller C-Stick Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
    댓글 쓰기
  5. Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: 5 단계, 이미지 3개 중 1개 Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: 5 단계, 이미지 3개 중 2개 Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
    댓글 쓰기
  6. Nintendo WaveBird Wireless Controller C-Stick Replacement, C-Stick: 6 단계, 이미지 2개 중 1개 Nintendo WaveBird Wireless Controller C-Stick Replacement, C-Stick: 6 단계, 이미지 2개 중 2개
    • Potential for device damage: Rough handling of the C-stick could cause the daughterboard to break off of the motherboard.
    • Grab the base of the yellow C-Stick cover with one hand and gently hold down the bottom piece of the motherboard with the spudger.
    • Pull off the yellow C-Stick cover.
    • During reassembly, make sure the slots inside the C-Stick cover line up with the motherboard so it can fit back together.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Garrett Leung
회원 가입일: 04/16/13
979 평판
안내서 8개를 작성함
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 회원
CPSU-AMIDO-S13S10G40
4 회원들
안내서 37개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 48
전체 시간: 3,025
