주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nobis NB07 Battery Replacement
필요한 것
    1. Nobis NB07 Battery Replacement, Opening the case: 1 단계, 이미지 1개 중 1개
      • Look towards the topside of the tablet, where the power button is located.
      • Insert a plastic opening tool in the crack between the two parts of the case.
      • Move it gently back and forth to open the case.
      댓글 쓰기
    2. Nobis NB07 Battery Replacement: 2 단계, 이미지 3개 중 1개 Nobis NB07 Battery Replacement: 2 단계, 이미지 3개 중 2개 Nobis NB07 Battery Replacement: 2 단계, 이미지 3개 중 3개
      • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
      • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
      댓글 쓰기
    3. Nobis NB07 Battery Replacement, Replacing the battery: 3 단계, 이미지 3개 중 1개 Nobis NB07 Battery Replacement, Replacing the battery: 3 단계, 이미지 3개 중 2개 Nobis NB07 Battery Replacement, Replacing the battery: 3 단계, 이미지 3개 중 3개
      • Remove the tape holding the battery in place.
      댓글 쓰기
    4. Nobis NB07 Battery Replacement: 4 단계, 이미지 3개 중 1개 Nobis NB07 Battery Replacement: 4 단계, 이미지 3개 중 2개 Nobis NB07 Battery Replacement: 4 단계, 이미지 3개 중 3개
      • Insert the flat end of the spudger tool in the crack beneath the battery.
      • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
      • This is a soft battery, so a little bending is expected.
      댓글 쓰기
    5. Nobis NB07 Battery Replacement: 5 단계, 이미지 1개 중 1개
      • After the battery is unglued, locate the cables that connect it to the motherboard.
      • Annotate where each color goes to make the reassembly easier.
      댓글 쓰기
    6. Nobis NB07 Battery Replacement: 6 단계, 이미지 2개 중 1개 Nobis NB07 Battery Replacement: 6 단계, 이미지 2개 중 2개
      • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
      • Review the Ifixit soldering guide if you need help soldering.
      • You can now remove the battery.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Daniel Gomero
회원 가입일: 01/21/15
966 평판
안내서 5개를 작성함
USF Tampa, Team 5-5, Brown Winter 2015 USF Tampa, Team 5-5, Brown Winter 2015 회원
USFT-BROWN-W15S5G5
3 회원들
안내서 11개를 작성함
1가이드 댓글
where do you find that battery? tried searching by the numbers on it and nothing
Scott Tuttle - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 34
전체 시간: 3,685
