Nokia 1010 Motherboard Replacement
This guide will give you step by step instructions on how to replace the motherboard. If you are having technical difficulties and this is may be related to the motherboard, this guide will give you full access to the motherboard system.
필요한 것
Using the spudger, pry back three tabs located on the left edge and three tabs located on the right edge of the body.
다른 17명이 해당 안내서를 완성하였습니다.
