주요 콘텐츠로 건너뛰기
Nokia 3310 3G Camera Replacement
Taylor Lyford
Taylor Lyford3 다른 기여자
최종 수정일 April 5, 2023
15 분
조정
In the event of a drop, the rear camera on the Nokia 3310 3G can be damaged. This guide will show the steps necessary to replace it.
필요한 것
도구
더보기...
  1. Nokia 3310 3G Camera Replacement, Battery: 1 단계, 이미지 2개 중 1개 Nokia 3310 3G Camera Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Camera Replacement: 2 단계, 이미지 2개 중 1개 Nokia 3310 3G Camera Replacement: 2 단계, 이미지 2개 중 2개
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Camera Replacement, Frame: 3 단계, 이미지 3개 중 1개 Nokia 3310 3G Camera Replacement, Frame: 3 단계, 이미지 3개 중 2개 Nokia 3310 3G Camera Replacement, Frame: 3 단계, 이미지 3개 중 3개
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Camera Replacement, Camera: 4 단계, 이미지 2개 중 1개 Nokia 3310 3G Camera Replacement, Camera: 4 단계, 이미지 2개 중 2개
    • Using the pointed metal spudger from the metal spudger set, insert the tool underneath the small snap clip, and disconnect it by lifting it up.
  5. Nokia 3310 3G Camera Replacement: 5 단계, 이미지 2개 중 1개 Nokia 3310 3G Camera Replacement: 5 단계, 이미지 2개 중 2개
    • The camera is held in with double sided and foam. Using the spudger, lift up on the camera to remove it from the motherboard of the phone.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Taylor Lyford
회원 가입일: 10/24/18
714 평판
안내서 3개를 작성함
UMass Dartmouth, Team S3-G3, Peak Fall 2018 UMass Dartmouth, Team S3-G3, Peak Fall 2018 회원
UMASSD-PEAK-F18S3G3
3 회원들
안내서 16개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 14
전체 시간: 917
