주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia 3310 3G Outer Frame Replacement
Aaron LeBlanc
Aaron LeBlanc2 다른 기여자
최종 수정일 2023년 4월 5일
25 분
조정
If the frame of your Nokia 3310 3G is cracked or damaged, this guide will help you replace it.
필요한 것
도구
더보기...
  1. Nokia 3310 3G Outer Frame Replacement, Battery: 1 단계, 이미지 2개 중 1개 Nokia 3310 3G Outer Frame Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Outer Frame Replacement: 2 단계, 이미지 2개 중 1개 Nokia 3310 3G Outer Frame Replacement: 2 단계, 이미지 2개 중 2개
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Outer Frame Replacement, Frame: 3 단계, 이미지 3개 중 1개 Nokia 3310 3G Outer Frame Replacement, Frame: 3 단계, 이미지 3개 중 2개 Nokia 3310 3G Outer Frame Replacement, Frame: 3 단계, 이미지 3개 중 3개
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Outer Frame Replacement, Motherboard: 4 단계, 이미지 3개 중 1개 Nokia 3310 3G Outer Frame Replacement, Motherboard: 4 단계, 이미지 3개 중 2개 Nokia 3310 3G Outer Frame Replacement, Motherboard: 4 단계, 이미지 3개 중 3개
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
  5. Nokia 3310 3G Outer Frame Replacement, Speaker: 5 단계, 이미지 2개 중 1개 Nokia 3310 3G Outer Frame Replacement, Speaker: 5 단계, 이미지 2개 중 2개
    • Using a metal spudger, lodge the tip underneath the speaker and between the soft foam surrounding the screen.
    • Use the metal spudger to leverage out the speaker.
    • The speaker is attached to the shell with an adhesive. Do not be too aggressive in your removal, else the speaker will come apart.
  6. Nokia 3310 3G Outer Frame Replacement, Outer Frame: 6 단계, 이미지 1개 중 1개
    • Using your finger, push the keyboard insert out of the front outer frame.
결론
다른 7명이 해당 안내서를 완성하였습니다.
향후 수리를 위한 준비
모두 쇼핑하기
작성자
2다른 기여자 명과 함께
Aaron LeBlanc
회원 가입일: 10/24/18
753 평판
안내서 5개를 작성함
UMass Dartmouth, Team S3-G3, Peak Fall 2018 UMass Dartmouth, Team S3-G3, Peak Fall 2018 회원
UMASSD-PEAK-F18S3G3
3 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 13
전체 시간: 1,225
