주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia 5310b XpressMusic Motherboard Replacement
Max Kirby
Max Kirby6 다른 기여자
최종 수정일 2025년 10월 25일
예상시간 없음
조정
학생이 작성 중
잘못된 도구
문법 검토
글머리 기호!
더 나은 소개글
세부 사항 누락
This repair will be going through removing and replacing the motherboard of a Nokia 5310b Xpress Music device. It is important to have a working motherboard in the device because it connects and controls the most essential electronic pieces of the device. A damaged or flawed motherboard will result in the device failing to turn on, not charging, not displaying clearly, having random freezes, or showing error messages. This can be caused by harsh handling of the phone, excessive water damage or simply a defective piece of the electronic.
Before using this guide, you can ensure that the problem is a resultant of the motherboard by replacing the battery or trying a different charger to see if that fixes the issue first.
To complete this guide you must be able to remove a screw with a screwdriver and use a spudger properly.
Before removing and replacing the motherboard, make sure that the phone is powered off and not connected to a power source (for example: charging).
필요한 것
도구
  1. Nokia 5310b XpressMusic Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Slide the black battery cover down and off the phone with your thumb to remove it.
    • The battery cover is not shown in this picture
  2. Nokia 5310b XpressMusic Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Nokia 5310b XpressMusic Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Gently lift the battery with a fingernail to remove it from the back of the phone.
    • Keep the battery removed for the next steps
    • The battery may be replaced or repaired at this step.
  3. Nokia 5310b XpressMusic Motherboard Replacement, Keypad: 3 단계, 이미지 3개 중 1개 Nokia 5310b XpressMusic Motherboard Replacement, Keypad: 3 단계, 이미지 3개 중 2개 Nokia 5310b XpressMusic Motherboard Replacement, Keypad: 3 단계, 이미지 3개 중 3개
    • On some models, the front case is screwed down from the back. Follow steps 5 and 6 first to remove the camera cover and two T6 screws, BEFORE removing the faceplate.
    • Find a small latch under the music keys and in the middle of each side of the faceplate.
    • Gently lift the edges of the front faceplate off the phone using a spudger.
  4. Nokia 5310b XpressMusic Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Nokia 5310b XpressMusic Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Flip the phone over to the front side.
    • Lift up the keypad from the bottom with either a spudger or your finger.
    • At this time the keypad can be removed and replaced.
  5. Nokia 5310b XpressMusic Motherboard Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Flip the phone over to the back side.
    • Unsnap the back camera cover from the phone.
    • Lift to remove the back camera cover from the phone after it has been unsnapped.
  6. Nokia 5310b XpressMusic Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Nokia 5310b XpressMusic Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Unscrew and remove the two screws on either side of the camera with the T6 Torx Screwdriver head.
    • Unscrew and remove the 4 screws located at each corner of the white keypad base using the T6 Torx Screwdriver head.
  7. Nokia 5310b XpressMusic Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Unclip the faceplate plug (ribbon) located in the lower left corner of the motherboard.
  8. Nokia 5310b XpressMusic Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Nokia 5310b XpressMusic Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Find the 2 metal clips located in the middle of the left and right sides of the motherboard.
    • Pry the 2 metal clips open up by using a spudger.
    • At this point the phone should come apart into 2 pieces (the motherboard/LCD screen and the faceplate).
결론
다른 4명이 해당 안내서를 완성하였습니다.
향후 수리를 위한 준비
모두 쇼핑하기
작성자
6다른 기여자 명과 함께
Max Kirby
회원 가입일: 05/01/11
518 평판
안내서 4개를 작성함
Cal Poly, Team 15-14, Regan Spring 2011 Cal Poly, Team 15-14, Regan Spring 2011 회원
CPSU-REGAN-S11S15G14
3 회원들
안내서 8개를 작성함
1가이드 댓글
Step 5 and 6 must be performed before step 3, otherwise, you will dislodge the thread from the front plate. so you have to remove the camera cover first, remove the 2 screws then you can remove the front plate without breaking anything.
Vincent Tschanz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 30
전체 시간: 7,174
