주요 콘텐츠로 건너뛰기
NuVision TM800A510L Screen Replacement
필요한 것
  1. NuVision TM800A510L Screen Replacement, Screen: 1 단계, 이미지 2개 중 1개 NuVision TM800A510L Screen Replacement, Screen: 1 단계, 이미지 2개 중 2개
    • Use a Heat Gun to heat the sides of the device and loosen the adhesive.
    • Heat the adhesive/device to just barely too hot to touch.
    • Pry up the the back of the device.
    • This process works best if you go one side at a time.
  2. NuVision TM800A510L Screen Replacement: 2 단계, 이미지 1개 중 1개
  3. NuVision TM800A510L Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Peel this connector off the device.
    • This is basically just a sticker, but go slow so you don't tear the connector.
  4. NuVision TM800A510L Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Slowly pull the speaker out of its bed.
    • The speaker piece is glued down.
  5. NuVision TM800A510L Screen Replacement: 5 단계, 이미지 2개 중 1개 NuVision TM800A510L Screen Replacement: 5 단계, 이미지 2개 중 2개
    • If you have not done so already, de-solder the boards from the device.
    • De-soldering the wires right now makes sure none of the wires are damaged or broken when we move the components.
  6. NuVision TM800A510L Screen Replacement: 6 단계, 이미지 1개 중 1개
    • The touch screen should lift right out of the device.
  7. NuVision TM800A510L Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Use the Heat Gun to heat the adhesive between the screen and edge protector.
    • Pry the two pieces apart.
    • Be careful of the circuit ribbon for the touch screen when prying the two pieces apart. The ribbon threads through both pieces.
    • Remember: Heating the device to 'almost to hot to touch' makes the process easier to work with.
    • Tip: Try the heating & prying process on one side of the device at a time.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kelsey Riggs
회원 가입일: 01/25/17
486 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 2,526
