소개
Learn how to replace the motherboard on the OLPC XO-4 Touch.
도구
부품
지정된 부품이 없습니다.
Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
Rotate the screen 180° and remove the other two screws.
Gently pull out the two antenna connectors by pulling them away from the motherboard.
Remove the four black 4mm screws from the metal cover using a Phillips #1 screwdriver.
Remove the metal cover from the laptop.
다른 한 분이 해당 안내서를 완성하였습니다.
