주요 콘텐츠로 건너뛰기
OLPC XO-4 Touch Mouse Buttons Controller Replacement
Michael Kellerman
Michael Kellerman6 다른 기여자
최종 수정일 November 30, 2019
20 분
조정
Use this guide to replace a broken mouse buttons controller.
필요한 것
도구
  1. OLPC XO-4 Touch Mouse Buttons Controller Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Mouse Buttons Controller Replacement: 2 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 2 단계, 이미지 2개 중 2개
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Mouse Buttons Controller Replacement: 3 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 3 단계, 이미지 2개 중 2개
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Mouse Buttons Controller Replacement, Keyboard: 4 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Mouse Buttons Controller Replacement, Keyboard: 4 단계, 이미지 2개 중 2개
    • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
  5. OLPC XO-4 Touch Mouse Buttons Controller Replacement: 5 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 5 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 5 단계, 이미지 3개 중 3개
    • Flip the laptop over to its normal position.
    • Lift the two antennas on both sides to unlock the screen.
    • Open the laptop.
  6. OLPC XO-4 Touch Mouse Buttons Controller Replacement: 6 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 6 단계, 이미지 2개 중 2개
    • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
    • Gently lift up on the back of the keyboard.
    • Pull the keyboard up far enough to expose the ribbon cable.
  7. OLPC XO-4 Touch Mouse Buttons Controller Replacement: 7 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 7 단계, 이미지 2개 중 2개
    • Gently lift up on the black connector to release the ribbon cable.
    • Gently pull the blue plastic tab up and away from the black connector.
    • Remove the keyboard from the laptop.
  8. OLPC XO-4 Touch Mouse Buttons Controller Replacement, Lower Case: 8 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Mouse Buttons Controller Replacement, Lower Case: 8 단계, 이미지 2개 중 2개
    • Close and flip the laptop over so you are looking at the battery compartment
    • Remove the five 4mm Phillips #1 screws from inside the battery compartment
  9. OLPC XO-4 Touch Mouse Buttons Controller Replacement: 9 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 9 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 9 단계, 이미지 3개 중 3개
    • Flip the laptop over, showing the top of the device.
    • Open the laptop and rotate the screen ninety degrees.
    • Tilt the screen so the lower right corner of the screen is closer to the lower case.
  10. OLPC XO-4 Touch Mouse Buttons Controller Replacement: 10 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 10 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 10 단계, 이미지 3개 중 3개
    • Push in and lift up on the keyboard edge of the white handle piece.
    • Pull the piece towards yourself to remove it from the laptop.
  11. OLPC XO-4 Touch Mouse Buttons Controller Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the four 4mm Phillips #1 screws attaching the green trim to the body of the computer.
  12. OLPC XO-4 Touch Mouse Buttons Controller Replacement: 12 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 12 단계, 이미지 2개 중 2개
    • Pry off the rear green trim piece.
  13. OLPC XO-4 Touch Mouse Buttons Controller Replacement: 13 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 13 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 13 단계, 이미지 3개 중 3개
    • Be careful not to pull the bottom portion of the laptop completely off, as there is a cable connecting it to the laptop.
    • Slide the green trim pieces away from the screen.
    • This should release the entire bottom portion of the laptop.
  14. OLPC XO-4 Touch Mouse Buttons Controller Replacement: 14 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 14 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 14 단계, 이미지 3개 중 3개
    • Unplug the cable from the mouse buttons controller to completely remove the lower frame from the device.
  15. OLPC XO-4 Touch Mouse Buttons Controller Replacement: 15 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 15 단계, 이미지 2개 중 2개
    • Rotate the entire lower assembly up slightly, and pull it away from the screen to free it from the screen hinge.
    • There may be some adhesive holding the cable to the metal plate. Gently pull the cable off of the plate if it is stuck.
  16. OLPC XO-4 Touch Mouse Buttons Controller Replacement, Mouse Buttons Controller: 16 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Mouse Buttons Controller Replacement, Mouse Buttons Controller: 16 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Mouse Buttons Controller Replacement, Mouse Buttons Controller: 16 단계, 이미지 3개 중 3개
    • You should now be looking at the bottom of the lower case.
    • Remove the eight 4mm Phillips #1 screws attaching the green trim pieces to the lower frame.
    • Pry off the front and side trim pieces.
  17. OLPC XO-4 Touch Mouse Buttons Controller Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the two 4mm Phillips #1 screws that attach the mouse buttons controller to the lower frame.
  18. OLPC XO-4 Touch Mouse Buttons Controller Replacement: 18 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 18 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Mouse Buttons Controller Replacement: 18 단계, 이미지 3개 중 3개
    • Disconnect the ribbon cable attached to the keyboard compartment.
    • Unplug the ribbon cable between the touchpad and the mouse buttons controller.
    • Remove the mouse buttons controller from the device.
결론
작성자
6다른 기여자 명과 함께
Michael Kellerman
회원 가입일: 01/24/13
58 평판
안내서 3개를 작성함
Cal Poly, Team 3-30, Amido Winter 2013 Cal Poly, Team 3-30, Amido Winter 2013 회원
CPSU-AMIDO-W13S3G30
3 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 4
전체 시간: 353
