주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OLPC XO-4 Touch Touchpad Controller Replacement
필요한 것
  1. OLPC XO-4 Touch Touchpad Controller Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop upside-down, with the handle facing away from you.
    댓글 쓰기
  2. OLPC XO-4 Touch Touchpad Controller Replacement: 2 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Touchpad Controller Replacement: 2 단계, 이미지 2개 중 2개
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
    댓글 쓰기
  3. OLPC XO-4 Touch Touchpad Controller Replacement: 3 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Touchpad Controller Replacement: 3 단계, 이미지 2개 중 2개
    • Lift up on the middle of the battery to remove it from the device.
    댓글 쓰기
  4. OLPC XO-4 Touch Touchpad Controller Replacement, Keyboard: 4 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Touchpad Controller Replacement, Keyboard: 4 단계, 이미지 2개 중 2개
    • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
    댓글 쓰기
  5. OLPC XO-4 Touch Touchpad Controller Replacement: 5 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Touchpad Controller Replacement: 5 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Touchpad Controller Replacement: 5 단계, 이미지 3개 중 3개
    • Flip the laptop over to its normal position.
    • Lift the two antennas on both sides to unlock the screen.
    • Open the laptop.
    댓글 쓰기
  6. OLPC XO-4 Touch Touchpad Controller Replacement: 6 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Touchpad Controller Replacement: 6 단계, 이미지 2개 중 2개
    • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
    • Gently lift up on the back of the keyboard.
    • Pull the keyboard up far enough to expose the ribbon cable.
    댓글 쓰기
  7. OLPC XO-4 Touch Touchpad Controller Replacement: 7 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Touchpad Controller Replacement: 7 단계, 이미지 2개 중 2개
    • Gently lift up on the black connector to release the ribbon cable.
    • Gently pull the blue plastic tab up and away from the black connector.
    • Remove the keyboard from the laptop.
    댓글 쓰기
  8. OLPC XO-4 Touch Touchpad Controller Replacement, Lower Case: 8 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Touchpad Controller Replacement, Lower Case: 8 단계, 이미지 2개 중 2개
    • Close and flip the laptop over so you are looking at the battery compartment
    • Remove the five 4mm Phillips #1 screws from inside the battery compartment
    댓글 쓰기
  9. OLPC XO-4 Touch Touchpad Controller Replacement: 9 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Touchpad Controller Replacement: 9 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Touchpad Controller Replacement: 9 단계, 이미지 3개 중 3개
    • Flip the laptop over, showing the top of the device.
    • Open the laptop and rotate the screen ninety degrees.
    • Tilt the screen so the lower right corner of the screen is closer to the lower case.
    댓글 쓰기
  10. OLPC XO-4 Touch Touchpad Controller Replacement: 10 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Touchpad Controller Replacement: 10 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Touchpad Controller Replacement: 10 단계, 이미지 3개 중 3개
    • Push in and lift up on the keyboard edge of the white handle piece.
    • Pull the piece towards yourself to remove it from the laptop.
    댓글 쓰기
  11. OLPC XO-4 Touch Touchpad Controller Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the four 4mm Phillips #1 screws attaching the green trim to the body of the computer.
    댓글 쓰기
  12. OLPC XO-4 Touch Touchpad Controller Replacement: 12 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Touchpad Controller Replacement: 12 단계, 이미지 2개 중 2개
    • Pry off the rear green trim piece.
    댓글 쓰기
  13. OLPC XO-4 Touch Touchpad Controller Replacement: 13 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Touchpad Controller Replacement: 13 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Touchpad Controller Replacement: 13 단계, 이미지 3개 중 3개
    • Be careful not to pull the bottom portion of the laptop completely off, as there is a cable connecting it to the laptop.
    • Slide the green trim pieces away from the screen.
    • This should release the entire bottom portion of the laptop.
    댓글 쓰기
  14. OLPC XO-4 Touch Touchpad Controller Replacement: 14 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Touchpad Controller Replacement: 14 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Touchpad Controller Replacement: 14 단계, 이미지 3개 중 3개
    • Unplug the cable from the mouse buttons controller to completely remove the lower frame from the device.
    댓글 쓰기
  15. OLPC XO-4 Touch Touchpad Controller Replacement: 15 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Touchpad Controller Replacement: 15 단계, 이미지 2개 중 2개
    • Rotate the entire lower assembly up slightly, and pull it away from the screen to free it from the screen hinge.
    • There may be some adhesive holding the cable to the metal plate. Gently pull the cable off of the plate if it is stuck.
    댓글 쓰기
  16. OLPC XO-4 Touch Touchpad Controller Replacement, Mouse Buttons Controller: 16 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Touchpad Controller Replacement, Mouse Buttons Controller: 16 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Touchpad Controller Replacement, Mouse Buttons Controller: 16 단계, 이미지 3개 중 3개
    • You should now be looking at the bottom of the lower case.
    • Remove the eight 4mm Phillips #1 screws attaching the green trim pieces to the lower frame.
    • Pry off the front and side trim pieces.
    댓글 쓰기
  17. OLPC XO-4 Touch Touchpad Controller Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the two 4mm Phillips #1 screws that attach the mouse buttons controller to the lower frame.
    댓글 쓰기
  18. OLPC XO-4 Touch Touchpad Controller Replacement: 18 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Touchpad Controller Replacement: 18 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Touchpad Controller Replacement: 18 단계, 이미지 3개 중 3개
    • Disconnect the ribbon cable attached to the keyboard compartment.
    • Unplug the ribbon cable between the touchpad and the mouse buttons controller.
    • Remove the mouse buttons controller from the device.
    댓글 쓰기
  19. OLPC XO-4 Touch Touchpad Controller Replacement, Touchpad Controller: 19 단계, 이미지 1개 중 1개
    • Remove the two 4mm Phillips screws that attach the metal plate to the touchpad assembly.
    • Be sure not to lose the silver magnet in the lower right corner of the touchpad assembly.
    댓글 쓰기
  20. OLPC XO-4 Touch Touchpad Controller Replacement: 20 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Touchpad Controller Replacement: 20 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Touchpad Controller Replacement: 20 단계, 이미지 3개 중 3개
    • Remove the silver contact tape from the metal plate.
    • Lift the metal plate off of the touchpad assembly.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Theodore Tsanakas
회원 가입일: 01/24/13
24 평판
안내서 1개를 작성함
Cal Poly, Team 3-30, Amido Winter 2013 Cal Poly, Team 3-30, Amido Winter 2013 회원
CPSU-AMIDO-W13S3G30
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 27
전체 시간: 843
