주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Oculus Rift Development Kit 2 Cable Hub Replacement
필요한 것
    1. Oculus Rift Development Kit 2 Cable Hub Replacement, Cable Hub: 1 단계, 이미지 1개 중 1개
      • Using the plastic opening tools, pry open the cable hub.
      댓글 쓰기
    2. Oculus Rift Development Kit 2 Cable Hub Replacement: 2 단계, 이미지 1개 중 1개
      • Carefully pry the cable away from the cable hub motherboard. It is attached with hot glue and should be removed easily.
      • Note that the cable is soldered on to the board. When prying the cable away from the hot glue, pull gently so as not to damage the soldered wire.
      댓글 쓰기
    3. Oculus Rift Development Kit 2 Cable Hub Replacement: 3 단계, 이미지 1개 중 1개
      • Desolder the wires as illustrated. This can be done by heating up the solder connecting the board and the wire. When the solder is liquified, pull the wire away from the board.
      • Need some help? Follow this guide to learn soldering basics.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alexandra Zaragoza
회원 가입일: 01/22/15
331 평판
안내서 1개를 작성함
Cal Poly, Team 18-5, Maness Winter 2015 Cal Poly, Team 18-5, Maness Winter 2015 회원
CPSU-MANESS-W15S18G5
4 회원들
안내서 42개를 작성함
4가이드 댓글
Buena guia, faltaria poder ver donde va soldado cada cable, he llevado mi cable a reparar y me lo han devuelto peor de lo que estaba, veo que han usado un cable de 4 hilos mas masa pero el original es de 5 hilos mas masa.
podria decirme donde van soldados los cables por la parte que va de la caja al usb ? ( el tramo corto )
Gracias
Hipolito Rodriguez - 답글 공유
Hipolito, pudíste arreglar el problema?
Yo tengo un DK2 que compré usado y vino sin la caja conectora del sensor. Hay forma de fabricar alguna? Reemeplazarla por alguna otra cosa?
Desde ya gracias.
Lea ndro - 답글 공유
Puedes conectar directamente el cable del sensor a las gafas, levantas la Tapita de goma que tiene y ahí lo conectas, con un alargador funciona correctamente también
My wires has a short in them where can i purchase a new one?
Ashley - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 26
전체 시간: 2,836
