주요 콘텐츠로 건너뛰기
Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement
Allen Anjal
Allen Anjal2 다른 기여자
최종 수정일 October 17, 2024
5 분
쉬움
The HDMI Connector Door (also referred to as the connector cover) allows access to both of the camera's connector ports; the HDMI connector port and the multi-connector port. In order to keep the connectors protected from outside damage, the Connector Door needs to be intact. If the HDMI Connector Door has been damaged, you can use this guide to ensure you are properly removing and replacing it.
필요한 것
도구
  1. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement, HDMI and Multi-connector Cover: 1 단계, 이미지 1개 중 1개
    • There are three different types and lengths of screws used to hold the bottom plate of the camera. Make proper note of each screws original position during your disassembly.
    • Using the PH00 Phillips-head screwdriver, unscrew the two 1/3 inch screws with silver threads from the the bottom of the camera.
    • Using the PH00 Phillips-head screwdriver, unscrew the three 1/3 inch screws with blue threads from the the bottom of the camera.
    • Using the PH00 Phillips-head screwdriver, unscrew the three 1/2 inch screws with silver threads from the the bottom of the camera.
  2. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: 2 단계, 이미지 1개 중 1개
    • After removing all of the screws, remove the bottom plate from the camera to continue.
  3. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: 3 단계, 이미지 2개 중 1개 Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: 3 단계, 이미지 2개 중 2개
    • Continuing to use the size PH00 Phillips-head screwdriver, remove the two 3/5 inch screws revealed after removing the bottom plate of the camera.
  4. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: 4 단계, 이미지 1개 중 1개
    • Open the HDMI connector door and continue to use the PH00 Phillips-head screwdriver to remove the 3/10 inch screw located underneath the door.
  5. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: 5 단계, 이미지 1개 중 1개
    • Proper removal of all 11 screws listed in the steps above from the camera gives the camera the ability to be opened slightly and allows for the door to be lifted off of the hooks holding it in place within the camera.
결론
To add your new HDMI connector door, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Allen Anjal
회원 가입일: 09/27/16
341 평판
안내서 2개를 작성함
USF Tampa, Team S5-G6, Eyestone Spring 2018 USF Tampa, Team S5-G6, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S5G6
4 회원들
안내서 15개를 작성함
1가이드 댓글
so, where can I buy the port cover or door for the OMD-em10 mark2? Thanks
Raffy Martinez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 60
전체 시간: 3,381
