주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnHub OnHub Antenna Array Replacement
필요한 것
    1. OnHub OnHub Antenna Array Replacement, Speaker Grille: 1 단계, 이미지 2개 중 1개 OnHub OnHub Antenna Array Replacement, Speaker Grille: 1 단계, 이미지 2개 중 2개
      • Make sure the device is unplugged before proceeding with the disassembly.
      • While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
      댓글 쓰기
    2. OnHub OnHub Antenna Array Replacement: 2 단계, 이미지 1개 중 1개
      • Place the plastic opening tool under the speaker grille, and just above the light ring.
      • Move the plastic opening tool around the groove while applying upward force to pry loose the 4 clips holding the grille in place.
      댓글 쓰기
    3. OnHub OnHub Antenna Array Replacement: 3 단계, 이미지 2개 중 1개 OnHub OnHub Antenna Array Replacement: 3 단계, 이미지 2개 중 2개
      • Using a metal spudger, carefully remove the congestion-sensor antenna by undoing the two clips.
      • There is a delicate wire connection to the antenna that is easily broken if not careful.
      댓글 쓰기
    1. OnHub OnHub Antenna Array Replacement, Congestion-sensing Antenna: 4 단계, 이미지 2개 중 1개 OnHub OnHub Antenna Array Replacement, Congestion-sensing Antenna: 4 단계, 이미지 2개 중 2개
      • Remove the wire connection to the antenna by soldering it off.
      • For help with soldering and de-soldering check out the iFixit Soldering Guide
      댓글 쓰기
    1. OnHub OnHub Antenna Array Replacement, Outer Casing: 5 단계, 이미지 2개 중 1개 OnHub OnHub Antenna Array Replacement, Outer Casing: 5 단계, 이미지 2개 중 2개
      • You must remove the plastic cover found just above the speaker.
      • Wedge the plastic opening tool under the cover and apply pressure in an upward direction.
      • There are four clips that you are removing. When disengaged, these clips will make a snapping noise.
      • Though the snapping noise is normal, take care not to break these clips.
      댓글 쓰기
    2. OnHub OnHub Antenna Array Replacement: 6 단계, 이미지 1개 중 1개
      • Upon removing the cover, four screws and the speaker housing will be exposed.
      • Unscrew the four 12mm screws using a #1 Phillips head screwdriver.
      • This unlocks the speaker housing and antenna array from the casing.
      댓글 쓰기
    3. OnHub OnHub Antenna Array Replacement: 7 단계, 이미지 2개 중 1개 OnHub OnHub Antenna Array Replacement: 7 단계, 이미지 2개 중 2개
      • On the bottom of the OnHub is two screws holding the casing to the base.
      • To access these screws, you must remove the rubber pad that is glued to the base.
      • To remove the pad, slide a metal spudger under the edge of the pad. Pry the pad away from the base, removing the glue.
      • Once the pad is pulled up enough to grab, peel it the rest of the way exposing the screws.
      • The rubber pad is thin and fragile; be careful not to tear when removing.
      댓글 쓰기
    4. OnHub OnHub Antenna Array Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the two 12mm screws under the base of the OnHub by using a #1 Phillips head screwdriver.
      댓글 쓰기
    5. OnHub OnHub Antenna Array Replacement: 9 단계, 이미지 2개 중 1개 OnHub OnHub Antenna Array Replacement: 9 단계, 이미지 2개 중 2개
      • Once the two screws are removed from the base, it is time to split the casing apart.
      • It is okay if a couple clips break. It will still hold together with a few remaining.
      • Wedge a spudger between the two casing halves, and pry the clips apart starting from the top
      • There are three hooking style clips in total.
      댓글 쓰기
    6. OnHub OnHub Antenna Array Replacement: 10 단계, 이미지 1개 중 1개
      • Once unclipped, you can slide the two casing halves apart, and remove the casing.
      댓글 쓰기
    1. OnHub OnHub Antenna Array Replacement, Speaker: 11 단계, 이미지 2개 중 1개 OnHub OnHub Antenna Array Replacement, Speaker: 11 단계, 이미지 2개 중 2개
      • Underneath the speaker is an intertwined black and white wire.
      • Disconnect the wire from its connection to the motherboard.
      댓글 쓰기
    2. OnHub OnHub Antenna Array Replacement: 12 단계, 이미지 1개 중 1개
      • The speaker should now easily come off with a firm grip on the OnHub device and pull.
      댓글 쓰기
    1. OnHub OnHub Antenna Array Replacement, OnHub Antenna Array: 13 단계, 이미지 1개 중 1개
      • There is a black, horizontal brace covering 12 wire connections.
      • Remove the brace, held by two screws
      댓글 쓰기
    2. OnHub OnHub Antenna Array Replacement: 14 단계, 이미지 2개 중 1개 OnHub OnHub Antenna Array Replacement: 14 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Make a note of each wire's position and color, so it will be easier to reconnect later.
      • Using tweezers, gently disconnect each of the 12 wire connections, attached to the top of the motherboard.
      • Be careful when removing the gold connectors as they are easily bent.
      • The connection points can be bent back if not damaged too badly.
      댓글 쓰기
    3. OnHub OnHub Antenna Array Replacement: 15 단계, 이미지 1개 중 1개
      • Make sure to carefully pull the tape style wire furthest to the left that is held by glue.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Mahir Abdella
회원 가입일: 02/10/16
331 평판
안내서 2개를 작성함
USF Tampa, Team 3-3, Sullivan Spring 2016 USF Tampa, Team 3-3, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S3G3
3 회원들
안내서 15개를 작성함
1가이드 댓글
That’s not a “tape-style wire”, that’s a ZIF flex cable! (ZIF is short for Zero Insertion Force)
To unplug that flex cable (which connects the LEDs to the main board) flip the little black bit at the other side of the connector up, then pull out the cable.
Jefferson - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 29
전체 시간: 925
