주요 콘텐츠로 건너뛰기
One Education Infinity Handle Replacement
Sarah Westberg
Sarah Westberg
최종 수정일 January 23, 2020
15 분
쉬움
In this guide you will learn how to replace the handle of your One Education Infinity. The handle is connected to the lower case with springs and Phillips #00 screws so it has give but is very secure. In the event that the handle becomes damaged, the process is very easy to replace. Be sure to power off and unplug your laptop prior to doing any work on your laptop, even the handle.
필요한 것
도구
더보기...
  1. One Education Infinity Handle Replacement, Back Case: 1 단계, 이미지 3개 중 1개 One Education Infinity Handle Replacement, Back Case: 1 단계, 이미지 3개 중 2개 One Education Infinity Handle Replacement, Back Case: 1 단계, 이미지 3개 중 3개
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity Handle Replacement: 2 단계, 이미지 2개 중 1개 One Education Infinity Handle Replacement: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity Handle Replacement: 3 단계, 이미지 3개 중 1개 One Education Infinity Handle Replacement: 3 단계, 이미지 3개 중 2개 One Education Infinity Handle Replacement: 3 단계, 이미지 3개 중 3개
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity Handle Replacement, Handle: 4 단계, 이미지 3개 중 1개 One Education Infinity Handle Replacement, Handle: 4 단계, 이미지 3개 중 2개 One Education Infinity Handle Replacement, Handle: 4 단계, 이미지 3개 중 3개
    • Using the Phillips #00, remove the two 4.7 mm screws securing the handle to the case.
  5. One Education Infinity Handle Replacement: 5 단계, 이미지 2개 중 1개 One Education Infinity Handle Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the handle from the device.
결론
Sarah Westberg
회원 가입일: 03/11/19
29,489 평판
안내서 71개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,537개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 100
