주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnePlus 5 Rear-Facing Camera Replacement
필요한 것
  1. OnePlus 5 Rear-Facing Camera Replacement, SIM Card Tray: 1 단계, 이미지 3개 중 1개 OnePlus 5 Rear-Facing Camera Replacement, SIM Card Tray: 1 단계, 이미지 3개 중 2개 OnePlus 5 Rear-Facing Camera Replacement, SIM Card Tray: 1 단계, 이미지 3개 중 3개
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole below the SIM card tray, located near the rear cameras on the edge of the phone.
    • Press firmly to eject the tray.
    • During reassembly, be sure to properly orient the SIM tray you you insert it.
    댓글 쓰기
  2. OnePlus 5 Rear-Facing Camera Replacement, Back Cover: 2 단계, 이미지 1개 중 1개
    • Remove the two 2.6 mm T2 screws straddling the USB-C port on the bottom edge of the phone.
    댓글 쓰기
  3. OnePlus 5 Rear-Facing Camera Replacement: 3 단계, 이미지 3개 중 1개 OnePlus 5 Rear-Facing Camera Replacement: 3 단계, 이미지 3개 중 2개 OnePlus 5 Rear-Facing Camera Replacement: 3 단계, 이미지 3개 중 3개
    • There is a high risk of damaging the display panel if this opening procedure is improperly followed.
    • The following four steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure.
    • There are two different seams between the body and the screen of the phone:
    • Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
    • Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
    • There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
    댓글 쓰기
  4. OnePlus 5 Rear-Facing Camera Replacement: 4 단계, 이미지 2개 중 1개 OnePlus 5 Rear-Facing Camera Replacement: 4 단계, 이미지 2개 중 2개
    • As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly.
    • Place a suction cup near the bottom edge of the display.
    • Pull on the suction cup with strong steady force.
    • Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
    • Due to tight tolerances, this will take substantial force. Using a new opening tool with an unmarred edge will help with this step.
    댓글 쓰기
  5. OnePlus 5 Rear-Facing Camera Replacement: 5 단계, 이미지 3개 중 1개 OnePlus 5 Rear-Facing Camera Replacement: 5 단계, 이미지 3개 중 2개 OnePlus 5 Rear-Facing Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
    • Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
    댓글 쓰기
  6. OnePlus 5 Rear-Facing Camera Replacement: 6 단계, 이미지 2개 중 1개 OnePlus 5 Rear-Facing Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Lever the opening tool to release the first clip from the frame.
    댓글 쓰기
  7. OnePlus 5 Rear-Facing Camera Replacement: 7 단계, 이미지 3개 중 1개 OnePlus 5 Rear-Facing Camera Replacement: 7 단계, 이미지 3개 중 2개 OnePlus 5 Rear-Facing Camera Replacement: 7 단계, 이미지 3개 중 3개
    • Continue sliding the opening tool along the long edge, releasing the clips along the way.
    • The last clip in the top-left corner near the front-facing camera is recessed and can be difficult to release. Take your time and use the flat end of a spudger or an opening pick to help.
    댓글 쓰기
  8. OnePlus 5 Rear-Facing Camera Replacement: 8 단계, 이미지 1개 중 1개
    • With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
    • The frame is still connected to the back cover by a long flex cable. Do not remove the back cover.
    • During reassembly, pause here to test your phone's functionality before securing the back cover.
    • To reinstall the back cover:
    • Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
    • Squeeze along the long edges of the phone to snap the remaining clips into place.
    댓글 쓰기
  9. OnePlus 5 Rear-Facing Camera Replacement: 9 단계, 이미지 3개 중 1개 OnePlus 5 Rear-Facing Camera Replacement: 9 단계, 이미지 3개 중 2개 OnePlus 5 Rear-Facing Camera Replacement: 9 단계, 이미지 3개 중 3개
    • With all the clips released, flip the phone over so that the display is face-down.
    • Swing the back cover around and rest it on top of the exposed frame.
    • Be careful not to stress the flex cable connecting the back cover and the frame.
    댓글 쓰기
  10. OnePlus 5 Rear-Facing Camera Replacement: 10 단계, 이미지 2개 중 1개 OnePlus 5 Rear-Facing Camera Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the 2.6 mm Phillips screw holding the cable bracket above the battery in place.
    • Lift up and remove the cable bracket.
    • To reinstall the bracket, position one end into place, and bend the bracket slightly to spring the other end into place.
    댓글 쓰기
  11. OnePlus 5 Rear-Facing Camera Replacement: 11 단계, 이미지 2개 중 1개 OnePlus 5 Rear-Facing Camera Replacement: 11 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the back cover flex cable from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    댓글 쓰기
  12. OnePlus 5 Rear-Facing Camera Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the back cover.
    댓글 쓰기
  13. OnePlus 5 Rear-Facing Camera Replacement, OnePlus 5 Battery Disconnect: 13 단계, 이미지 2개 중 1개 OnePlus 5 Rear-Facing Camera Replacement, OnePlus 5 Battery Disconnect: 13 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the battery connector from its socket.
    댓글 쓰기
  14. OnePlus 5 Rear-Facing Camera Replacement, Rear-Facing Camera: 14 단계, 이미지 3개 중 1개 OnePlus 5 Rear-Facing Camera Replacement, Rear-Facing Camera: 14 단계, 이미지 3개 중 2개 OnePlus 5 Rear-Facing Camera Replacement, Rear-Facing Camera: 14 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry up and disconnect the two rear-facing camera connectors from their sockets on the motherboard.
    댓글 쓰기
  15. OnePlus 5 Rear-Facing Camera Replacement: 15 단계, 이미지 2개 중 1개 OnePlus 5 Rear-Facing Camera Replacement: 15 단계, 이미지 2개 중 2개
    • Insert the point of a spudger under the top left corner of the camera module and pry up to loosen it from its recess.
    댓글 쓰기
  16. OnePlus 5 Rear-Facing Camera Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the rear-facing camera module.
    댓글 쓰기
결론
Repair didn’t go as planned? Check out our OnePlus 5 Answers Community for troubleshooting help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
343,966 평판
안내서 915개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 42
전체 시간: 4,352
