주요 콘텐츠로 건너뛰기
OnePlus 5T AMOLED Screen & Digitizer Replacement
필요한 것
  1. OnePlus 5T AMOLED Screen & Digitizer Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Before you begin, switch off your phone.
    • Remove the SIM card tray.
  2. OnePlus 5T AMOLED Screen & Digitizer Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two Torx T2 screws (2.5 mm length).
    • The OnePlus 5T doesn't use a lot of adhesive to secure the backcover, however the clamps are very strong and require some force during the opening procedure.
  3. OnePlus 5T AMOLED Screen & Digitizer Replacement: 3 단계, 이미지 3개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 3 단계, 이미지 3개 중 2개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 3 단계, 이미지 3개 중 3개
    • Insert an opening tool between the display and the backcover at the bottom end of the phone.
    • Use the opening tool to create a gap between back cover and display.
    • Insert an opening pick in the gap you created with the opening tool.
  4. OnePlus 5T AMOLED Screen & Digitizer Replacement: 4 단계, 이미지 3개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 4 단계, 이미지 3개 중 2개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 4 단계, 이미지 3개 중 3개
    • Slide the opening pick to the bottom right corner of the phone.
    • Insert a second opening pick and slide it to the bottom left corner of the phone.
  5. OnePlus 5T AMOLED Screen & Digitizer Replacement: 5 단계, 이미지 3개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 5 단계, 이미지 3개 중 2개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 5 단계, 이미지 3개 중 3개
    • Slide the opening pick around the bottom left corner and then up along the left edge of the phone to open the plastic clamps that secure the backcover.
  6. OnePlus 5T AMOLED Screen & Digitizer Replacement: 6 단계, 이미지 3개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 6 단계, 이미지 3개 중 2개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 6 단계, 이미지 3개 중 3개
    • Slide the opening pick around the bottom right corner and then up along the right edge of the phone to open the plastic clamps that secure the backcover.
  7. OnePlus 5T AMOLED Screen & Digitizer Replacement: 7 단계, 이미지 3개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 7 단계, 이미지 3개 중 2개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 7 단계, 이미지 3개 중 3개
    • Try not to remove the backcover all the way yet. The fingerprint and the charging port and headphone flex cables are still connected to the motherboard.
    • Flip your phone and carefully lift the bottom end of the backcover away from the phone assembly. Fold it to left and hold it at an 80° angle.
  8. OnePlus 5T AMOLED Screen & Digitizer Replacement: 8 단계, 이미지 2개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 8 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the fingerprint flex cable.
  9. OnePlus 5T AMOLED Screen & Digitizer Replacement: 9 단계, 이미지 3개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 9 단계, 이미지 3개 중 2개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 9 단계, 이미지 3개 중 3개
    • Twist the backcover around 180° and lay it down to align the bottom end of the backcover the top edge of the battery.
  10. OnePlus 5T AMOLED Screen & Digitizer Replacement: 10 단계, 이미지 3개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 10 단계, 이미지 3개 중 2개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 10 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the small metal shield which covers the battery and the charging port and headphone jack flex cable connectors.
  11. OnePlus 5T AMOLED Screen & Digitizer Replacement: 11 단계, 이미지 2개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 11 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the charging port and headphone jack flex cable.
  12. OnePlus 5T AMOLED Screen & Digitizer Replacement: 12 단계, 이미지 2개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the backcover.
  13. OnePlus 5T AMOLED Screen & Digitizer Replacement, Battery Disconnect: 13 단계, 이미지 2개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement, Battery Disconnect: 13 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the battery flex cable.
  14. OnePlus 5T AMOLED Screen & Digitizer Replacement, Speaker: 14 단계, 이미지 1개 중 1개
    • Remove the six Phillips #00 screws (2.9 mm length).
  15. OnePlus 5T AMOLED Screen & Digitizer Replacement: 15 단계, 이미지 3개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 15 단계, 이미지 3개 중 2개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 15 단계, 이미지 3개 중 3개
    • Slide an opening pick underneath the left side of the speaker.
    • Use the opening pick to pry the speaker up and out of its recess.
  16. OnePlus 5T AMOLED Screen & Digitizer Replacement: 16 단계, 이미지 2개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the speaker.
  17. OnePlus 5T AMOLED Screen & Digitizer Replacement, AMOLED Screen & Digitizer: 17 단계, 이미지 2개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement, AMOLED Screen & Digitizer: 17 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the display flex cable.
  18. OnePlus 5T AMOLED Screen & Digitizer Replacement: 18 단계, 이미지 2개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 18 단계, 이미지 2개 중 2개
    • Slide an opening pick under the left side of the interconnect cable and pry it up.
    • The interconnect cable is held in place by mild adhesive. In case you're having trouble removing it, you can apply a heated iOpener to loosen the adhesive underneath.
  19. OnePlus 5T AMOLED Screen & Digitizer Replacement: 19 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the screen and all edges of the phone for at least two minutes, to loosen the adhesive.
  20. OnePlus 5T AMOLED Screen & Digitizer Replacement: 20 단계, 이미지 3개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 20 단계, 이미지 3개 중 2개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 20 단계, 이미지 3개 중 3개
    • If the phone's screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Once the screen is warm to the touch, apply a suction cup to the bottom edge of the phone.
    • Pull the suction cup upwards and insert an opening pick in the gap between the display glass and the midframe. Start to cut the adhesive by sliding the opening pick to the bottom right corner.
  21. OnePlus 5T AMOLED Screen & Digitizer Replacement: 21 단계, 이미지 2개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 21 단계, 이미지 2개 중 2개
    • Insert a second opening pick and slide it to the bottom left corner of the phone to cut the adhesive.
    • Leave the picks in place to prevent the adhesive from resealing.
  22. OnePlus 5T AMOLED Screen & Digitizer Replacement: 22 단계, 이미지 3개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 22 단계, 이미지 3개 중 2개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 22 단계, 이미지 3개 중 3개
    • Insert a third opening pick under the bottom left corner of the phone.
    • Slide the opening pick up to the top left corner to cut the adhesive. Leave it there to prevent the adhesive from resealing.
    • If cutting becomes too difficult, reheat and reapply the iOpener.
  23. OnePlus 5T AMOLED Screen & Digitizer Replacement: 23 단계, 이미지 2개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 23 단계, 이미지 2개 중 2개
    • Insert a fourth opening pick at the top left corner.
    • When nearing the front facing camera, only work with the tip of the opening pick to avoid damaging or smearing the camera.
    • Slide the opening pick along the top edge of the phone to cut the adhesive. Leave the pick in the top right corner of the screen to prevent the adhesive from resealing.
  24. OnePlus 5T AMOLED Screen & Digitizer Replacement: 24 단계, 이미지 2개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 24 단계, 이미지 2개 중 2개
    • Insert a fifth opening pick and slide it along the right edge of the phone to cut the remaining adhesive.
    • Try not to remove the display all the way yet, the display cable is still threaded through the frame and possible adhered on the inner side of the midframe.
  25. OnePlus 5T AMOLED Screen & Digitizer Replacement: 25 단계, 이미지 3개 중 1개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 25 단계, 이미지 3개 중 2개 OnePlus 5T AMOLED Screen & Digitizer Replacement: 25 단계, 이미지 3개 중 3개
    • Thread the display flex cable through the gap in the midframe and remove the display.
    • Before installing a new display, remove all traces of the old adhesive from the frame, and clean the glued areas with isopropyl alcohol (>90%) and a lint-free cloth.
    • If your replacement part doesn't come with preattached adhesive, the best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
결론
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
246,910 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,648개를 작성함
1가이드 댓글
What adhesive do you use? B-7000 glue , 1mm or 2mm adhesive tape?
purepeanutz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 29
지난 30일: 167
전체 시간: 26,967
