주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnePlus 6 Motherboard Replacement
필요한 것
  1. OnePlus 6 Motherboard Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
    댓글 쓰기
  2. OnePlus 6 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 OnePlus 6 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
    댓글 쓰기
  3. OnePlus 6 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 OnePlus 6 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
    댓글 쓰기
  4. OnePlus 6 Motherboard Replacement, Battery: 4 단계, 이미지 2개 중 1개 OnePlus 6 Motherboard Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Grip the green tab connected to the battery and pull the battery directly up and out.
    댓글 쓰기
  5. OnePlus 6 Motherboard Replacement, Fingerprint sensor: 5 단계, 이미지 2개 중 1개 OnePlus 6 Motherboard Replacement, Fingerprint sensor: 5 단계, 이미지 2개 중 2개
    • The midframe is made of plastic and located above the battery space.
    • Using the Phillips #00 screwdriver, remove the ten 3 mm screws from the midframe.
    • ATTENTION - Be aware that the 10th screw is actually underneath the round white sticker marked with the green circle at the bottom left. Do not remove the screw next to it marked with the orange circle or you will damage your midframe board.
    • Lift the bottom of the mid frame directly up and remove it from the device.
    댓글 쓰기
  6. OnePlus 6 Motherboard Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
    • Remove the ten screws holding the motherboard using a Phillips #00 screwdriver.
    댓글 쓰기
  7. OnePlus 6 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 OnePlus 6 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the small metal tabs near the battery compartment that are holding the motherboard down.
    • Using a fingernail, carefully work under the edge and pry the motherboard up from the phone.
    • The cameras should lift up with the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
John Steven Trammell
회원 가입일: 09/28/21
961 평판
안내서 4개를 작성함
Clemson, Team 4-3, Hunter Fall 2021 Clemson, Team 4-3, Hunter Fall 2021 회원
CLEM-HUNTER-F21S4G3
5 회원들
안내서 28개를 작성함
1가이드 댓글
Can you repair my One plus 6. It's one IC of motherboard is damaged.
AMIT PANWAR - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 30
지난 30일: 123
전체 시간: 5,591
