주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Opening Procedure
필요한 것
  1. Opening Procedure, Power down your watch: 1 단계, 이미지 2개 중 1개 Opening Procedure, Power down your watch: 1 단계, 이미지 2개 중 2개
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
    댓글 쓰기
  2. Opening Procedure, Loosen the adhesive: 2 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    댓글 쓰기
  3. Opening Procedure, Insert an opening pick: 3 단계, 이미지 3개 중 1개 Opening Procedure, Insert an opening pick: 3 단계, 이미지 3개 중 2개 Opening Procedure, Insert an opening pick: 3 단계, 이미지 3개 중 3개
    • Insert an opening pick into the recess between the watch frame and the top edge of the back cover.
    • Push the opening pick to create a gap between the back cover and the watch frame.
    댓글 쓰기
  4. Opening Procedure, Pry up the back cover assembly: 4 단계, 이미지 3개 중 1개 Opening Procedure, Pry up the back cover assembly: 4 단계, 이미지 3개 중 2개 Opening Procedure, Pry up the back cover assembly: 4 단계, 이미지 3개 중 3개
    • Twist the opening pick to widen the gap between the back cover assembly and the watch frame.
    • Pry upward to loosen the back cover assembly.
    • Don't try to remove the back cover assembly all the way yet. It's still connected to the motherboard.
    댓글 쓰기
  5. Opening Procedure, Free the back cover assembly: 5 단계, 이미지 2개 중 1개 Opening Procedure, Free the back cover assembly: 5 단계, 이미지 2개 중 2개
    • Carefully lift up the bottom edge of the back cover assembly to make sure it isn't adhered to the watch frame anymore.
    • Avoid straining or tearing the sensor or battery cables.
    댓글 쓰기
  6. Opening Procedure, Open the watch: 6 단계, 이미지 2개 중 1개 Opening Procedure, Open the watch: 6 단계, 이미지 2개 중 2개
    • Grab the back cover assembly and carefully bring it into an upright position next to the watch housing.
    댓글 쓰기
  7. Opening Procedure, Disconnect the battery cable: 7 단계, 이미지 2개 중 1개 Opening Procedure, Disconnect the battery cable: 7 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    댓글 쓰기
  8. Opening Procedure, Disconnect the sensor cable: 8 단계, 이미지 2개 중 1개 Opening Procedure, Disconnect the sensor cable: 8 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the sensor cable by prying the connector straight up from its socket.
    댓글 쓰기
  9. Opening Procedure, Remove the back cover assembly: 9 단계, 이미지 2개 중 1개 Opening Procedure, Remove the back cover assembly: 9 단계, 이미지 2개 중 2개
    • Remove the back cover assembly.
    댓글 쓰기
결론
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch E3 answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
259,250 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 25,939개를 작성함
1가이드 댓글
I appreciate the details and sequence of photos. I hope I won't need this guide, but it's comforting to know you put this together!
BruceG - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 37
전체 시간: 689
