주요 콘텐츠로 건너뛰기
Optoma PRO360W Bulb Replacement
Desiree Benitez
Desiree Benitez3 다른 기여자
최종 수정일 January 27, 2025
8 분
쉬움
마크업 사고
단계 다듬기
This guide will provide a step-by-step process on how to safely remove and replace a light bulb for an Optoma PRO360W projector. In the process of this removal, we will demonstrate how to clean the area of any dust and how to recycle the waste material- the old light bulb.
필요한 것
도구
  1. Optoma PRO360W Bulb Replacement, Unplug projector: 1 단계, 이미지 1개 중 1개
    • Unplug the projector from the wall outlet to allow for the light bulb to cool for at least 30 minutes.
  2. Optoma PRO360W Bulb Replacement: 2 단계, 이미지 1개 중 1개
    • On the bottom side of the projector, locate and unscrew the back cover using a Philip's head screwdriver.
  3. Optoma PRO360W Bulb Replacement: 3 단계, 이미지 1개 중 1개
    • Unscrew the bulb screws on either side of the silver plate.
  4. Optoma PRO360W Bulb Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the light bulb from the projector by lifting the silver handle and pulling up.
  5. Optoma PRO360W Bulb Replacement: 5 단계, 이미지 1개 중 1개
    • Clean the now vacant area where the light bulb once belonged of dust and particles using a Q-tip.
  6. Optoma PRO360W Bulb Replacement: 6 단계, 이미지 1개 중 1개
    • Use a new Q-tip to clean the fan blades and hole in which the light enters.
  7. Optoma PRO360W Bulb Replacement: 7 단계, 이미지 1개 중 1개
    • Open and remove the new light bulb from its box with clean hands to prevent from getting the bulb dirty.
  8. Optoma PRO360W Bulb Replacement: 8 단계, 이미지 1개 중 1개
    • Place the new bulb inside making sure to align the bulb towards the light hole and the wire connector towards the wire receiver.
  9. Optoma PRO360W Bulb Replacement: 9 단계, 이미지 1개 중 1개
    • Dispose of the bulb by sending it to a recycling center.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Desiree Benitez
회원 가입일: 01/21/17
128 평판
안내서 1개를 작성함
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 회원
USFSM-STEWART-S17S1G1
19 회원들
안내서 22개를 작성함
댓글 한 개
Thanks for your guide provide a step-by-step process on how to safely remove and replace a light bulb for a Ben-Q projector , how to projector Epson, is it same? because i have rental LCD Projector, definitely one day need
ericserianto - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 16
전체 시간: 844
