Oral-B Vitality Battery Replacement
Electric toothbrushes are powered by a rechargeable battery, that enables the reciprocating brushing motion of the bristles. If your electric toothbrush loses power quickly or doesn't hold charge, most likely the rechargeable battery needs to be replaced.
필요한 것
부품
도구
더보기...
To reassemble your device, follow these instructions in reverse order. Remember to apply just enough solder to re-attach the terminals.
다른 18명이 해당 안내서를 완성하였습니다.
댓글 9개
This is very easy to do. I had no problems following your instructions.
Ian Bowker - 답글
Thanks.
Is this a regular rechargeable AA?
Thanks again.
The original battery is a NiCd with tabs. I just spot welded tabs onto a standard AA NiMH battery and it worked fine.
T C -
@stephen Shaw These batteries worked for me: https://www.amazon.com/dp/B00CR0R8KQ/ref...
