주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Orbo Jr. Motherboard Replacement
필요한 것
  1. Orbo Jr. Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use your thumbs to gently pry the silicon case away from the tablet starting at one of the corners. Once the first corner is separated the other three corners should slip off easily.
    댓글 쓰기
  2. Orbo Jr. Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Orbo Jr. Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Orbo Jr. Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to pry the back off the tablet. Work your way around the edges. Once you have one side open you can slowly unsnap the rest of the case and use the tool as needed.
    • Go slowly when you pry the back off to ensure you do not crack the case or damage the screen.
    댓글 쓰기
  3. Orbo Jr. Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Gently pull the cables attached to the speaker to remove it from the back cover.
    • The speaker is taped in the back cover and caution should be used when pulling on the wires.
    댓글 쓰기
  4. Orbo Jr. Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Pull back the tape to expose the wires that are attached to the battery.
    댓글 쓰기
  5. Orbo Jr. Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Orbo Jr. Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Do not attempt to fully remove the battery. It is still connected to the motherboard by two wires.
    • Use a nylon spudger to lift the battery from the right side of the device. Slowly remove the adhesive below the battery.
    • To avoid damage to device and battery, do not attempt to remove the battery until adhesive is completely detached.
    댓글 쓰기
  6. Orbo Jr. Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Orbo Jr. Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Orbo Jr. Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Desolder the battery wires from the positive and negative connection to the motherboard. Check out iFixit's How to Solder and Desolder Connections guide for soldering help.
    • Positive and Negative battery terminals.
    • Be careful to not make contact to other components on the motherboard while using the soldering iron.
    댓글 쓰기
  7. Orbo Jr. Motherboard Replacement, Speaker: 7 단계, 이미지 3개 중 1개 Orbo Jr. Motherboard Replacement, Speaker: 7 단계, 이미지 3개 중 2개 Orbo Jr. Motherboard Replacement, Speaker: 7 단계, 이미지 3개 중 3개
    • Unsolder the positive and negative speaker wires from the connection on the motherboard.
    • Be careful to not make contact to other components on the motherboard while using the solder iron.
    댓글 쓰기
  8. Orbo Jr. Motherboard Replacement, Camera: 8 단계, 이미지 3개 중 1개 Orbo Jr. Motherboard Replacement, Camera: 8 단계, 이미지 3개 중 2개 Orbo Jr. Motherboard Replacement, Camera: 8 단계, 이미지 3개 중 3개
    • Use the pointed end of a spudger to flip up the black tab connecting the camera's ribbon cable to the motherboard.
    • Camera ribbon clip.
    • Pull lightly on the ribbon to remove the camera ribbon from the tab.
    댓글 쓰기
  9. Orbo Jr. Motherboard Replacement, Motherboard: 9 단계, 이미지 3개 중 1개 Orbo Jr. Motherboard Replacement, Motherboard: 9 단계, 이미지 3개 중 2개 Orbo Jr. Motherboard Replacement, Motherboard: 9 단계, 이미지 3개 중 3개
    • Unsolder the Wifi wire from the connection on the motherboard.
    • WiFi terminal
    댓글 쓰기
  10. Orbo Jr. Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Orbo Jr. Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Orbo Jr. Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Unsolder the display wires from the connection on the motherboard.
    • Display wires
    댓글 쓰기
  11. Orbo Jr. Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Use the flat end of the spudger to lift and remove the black tape covering the ribbon connection tab.
    • The tape should be removed slowly.
    댓글 쓰기
  12. Orbo Jr. Motherboard Replacement: 12 단계, 이미지 3개 중 1개 Orbo Jr. Motherboard Replacement: 12 단계, 이미지 3개 중 2개 Orbo Jr. Motherboard Replacement: 12 단계, 이미지 3개 중 3개
    • Using the tip end of the spudger, slide back the black clips on the side of the right ribbon connection.
    • Gently pull the display ribbons to remove them from the motherboard connections.
    • Repeat the same steps for the left ribbon connection.
    댓글 쓰기
  13. Orbo Jr. Motherboard Replacement: 13 단계, 이미지 3개 중 1개 Orbo Jr. Motherboard Replacement: 13 단계, 이미지 3개 중 2개 Orbo Jr. Motherboard Replacement: 13 단계, 이미지 3개 중 3개
    • Remove the following Phillips #000 screws securing the motherboard.
    • Three 3.0 mm screws
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Ryan Christman
회원 가입일: 02/10/16
684 평판
안내서 5개를 작성함
USF Tampa, Team 3-1, Sullivan Spring 2016 USF Tampa, Team 3-1, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S3G1
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 34
전체 시간: 690
