주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Oster 6329 Power Cord Replacement
필요한 것
    1. Oster 6329 Power Cord Replacement, Outer Shell Removal: 1 단계, 이미지 2개 중 1개 Oster 6329 Power Cord Replacement, Outer Shell Removal: 1 단계, 이미지 2개 중 2개
      • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
      댓글 쓰기
    2. Oster 6329 Power Cord Replacement: 2 단계, 이미지 1개 중 1개
      • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
      댓글 쓰기
    3. Oster 6329 Power Cord Replacement: 3 단계, 이미지 1개 중 1개
      • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
      • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
      댓글 쓰기
    4. Oster 6329 Power Cord Replacement: 4 단계, 이미지 2개 중 1개 Oster 6329 Power Cord Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
      댓글 쓰기
    5. Oster 6329 Power Cord Replacement: 5 단계, 이미지 2개 중 1개 Oster 6329 Power Cord Replacement: 5 단계, 이미지 2개 중 2개
      • Lift the top outer metal shell.
      • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
      댓글 쓰기
    1. Oster 6329 Power Cord Replacement, Power Cord: 6 단계, 이미지 1개 중 1개
      • Using a flat-head screwdriver, pry the power cord from the base of the toaster.
      댓글 쓰기
    2. Oster 6329 Power Cord Replacement: 7 단계, 이미지 1개 중 1개
      • Using a flat-head screwdriver, pry the white wire from the base.
      댓글 쓰기
    3. Oster 6329 Power Cord Replacement: 8 단계, 이미지 1개 중 1개
      • Locate the circuit board at the front of the toaster where the power cord and white wire meet.
      • Pull the circuit board up and out to free the circuit board from the body of the toaster.
      • It is tightly fit and may take moderate force to remove.
      댓글 쓰기
    4. Oster 6329 Power Cord Replacement: 9 단계, 이미지 2개 중 1개 Oster 6329 Power Cord Replacement: 9 단계, 이미지 2개 중 2개
      • Desolder the power cord from the circuit board at the locations show in the diagram.
      • For soldering instructions see the iFixit Soldering Guide.
      • The wires should be free from board when un-soldering is complete.
      댓글 쓰기
    5. Oster 6329 Power Cord Replacement: 10 단계, 이미지 2개 중 1개 Oster 6329 Power Cord Replacement: 10 단계, 이미지 2개 중 2개
      • Unscrew the two 1.5cm Phillips-head screws at the back of the toaster that are holding the power cord in place to remove the retaining clip.
      • Remove the plastic retaining clip that is holding the cord in place.
      댓글 쓰기
    6. Oster 6329 Power Cord Replacement: 11 단계, 이미지 2개 중 1개 Oster 6329 Power Cord Replacement: 11 단계, 이미지 2개 중 2개
      • Untie the knot in the power cord.
      댓글 쓰기
    7. Oster 6329 Power Cord Replacement: 12 단계, 이미지 1개 중 1개
      • Pull the cord from the base to remove the cable.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Timothy Grijalva
회원 가입일: 01/31/14
234 평판
안내서 2개를 작성함
Cal Poly, Team 13-15, Regan Winter 2014 Cal Poly, Team 13-15, Regan Winter 2014 회원
CPSU-REGAN-W14S13G15
5 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 34
전체 시간: 1,392
