P775DM3 Motherboard replacement
Unscrew the two screws circled in red.
Slide the plate in the direction of the arrow.
Unscrew the screw circled in red.
Lift the disk with the green tab.
Remove the disk in the direction of the arrow.
Disconnect the two connectors circled in green.
Remove the WLAN card.
Unscrew the four large screws circled in green
Unscrew the five small screws circled in red
Lift the cooler with the two tabs circled in blue
Lift the flap that holds the two connectors framed in red.
Disconnect the two framed connectors in red.
To reassemble your device, follow the instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
