주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PDP Rematch Top Left and Right Button(s) Replacement
필요한 것
  1. PDP Rematch Top Left and Right Button(s) Replacement, Faceplate: 1 단계, 이미지 2개 중 1개 PDP Rematch Top Left and Right Button(s) Replacement, Faceplate: 1 단계, 이미지 2개 중 2개
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
    댓글 쓰기
  2. PDP Rematch Top Left and Right Button(s) Replacement: 2 단계, 이미지 2개 중 1개 PDP Rematch Top Left and Right Button(s) Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
    댓글 쓰기
  3. PDP Rematch Top Left and Right Button(s) Replacement: 3 단계, 이미지 2개 중 1개 PDP Rematch Top Left and Right Button(s) Replacement: 3 단계, 이미지 2개 중 2개
    • Gently lift off the hard cover with your hand; it should not need much force.
    댓글 쓰기
  4. PDP Rematch Top Left and Right Button(s) Replacement, Top Left and Right Buttons: 4 단계, 이미지 2개 중 1개 PDP Rematch Top Left and Right Button(s) Replacement, Top Left and Right Buttons: 4 단계, 이미지 2개 중 2개
    • Remove the back panel by pulling it away from the front.
    • Disconnect the cable by squeezing the two sides while pulling the cable away from the motherboard.
    댓글 쓰기
  5. PDP Rematch Top Left and Right Button(s) Replacement: 5 단계, 이미지 2개 중 1개 PDP Rematch Top Left and Right Button(s) Replacement: 5 단계, 이미지 2개 중 2개
    • Touch the hot tip of the soldering iron to the first solder connecting the buttons to the motherboard until the solder melts.
    • Repeat this for the next solder. Verify solders have detached from motherboard.
    • Be careful of the hot soldering tip.
    댓글 쓰기
  6. PDP Rematch Top Left and Right Button(s) Replacement: 6 단계, 이미지 2개 중 1개 PDP Rematch Top Left and Right Button(s) Replacement: 6 단계, 이미지 2개 중 2개
    • When the solder has completely melted, flip the controller and gently pull the wire free from the motherboard.
    • Repeat for the other black wire.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
GraceGrubbs
회원 가입일: 01/24/24
147 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 27
전체 시간: 521
