주요 콘텐츠로 건너뛰기
PS3 Dual Shock 3 Controler Charging Port Replacement
Attak
Attak3 다른 기여자
최종 수정일 October 14, 2024
1 - 2 시간
어려움
커뮤니티-기여 안내서
To complete this repair, the user must possess skills in soldering, and proper tools needed to perform the repair.
  1. PS3 Dual Shock 3 Controler Charging Port Replacement, Opening the Controller: 1 단계, 이미지 1개 중 1개
    • Remove the 5 screws on the back of the controller.
    • The back housing of the controller can now be removed.
  2. PS3 Dual Shock 3 Controler Charging Port Replacement, Removing the Battery: 2 단계, 이미지 1개 중 1개
    • Remove battery by unlatching the battery cables from battery connector clip.
  3. PS3 Dual Shock 3 Controler Charging Port Replacement, Freeing the Motherboard: 3 단계, 이미지 1개 중 1개
    • Remove the two screws holding the motherboard to the front controller housing.
    • Next, remove the motherboard assembly from the controller housing. This is done by pressing in the clips on each side of the handle.
    • Freeing the motherboard from the housing will provide better access to the charging port.
  4. PS3 Dual Shock 3 Controler Charging Port Replacement, Preparing the Soldering Station: 4 단계, 이미지 1개 중 1개
    • Prepare your station for the de-soldering of the charging port.
  5. PS3 Dual Shock 3 Controler Charging Port Replacement, Desoldering: 5 단계, 이미지 3개 중 1개 PS3 Dual Shock 3 Controler Charging Port Replacement, Desoldering: 5 단계, 이미지 3개 중 2개 PS3 Dual Shock 3 Controler Charging Port Replacement, Desoldering: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    • To remove the defective charging port, you will need to de-solder the 9 pins holding the port to the motherboard.
    • First, used the desoldering pump to remove the solder from all 9 pins.
    • Then, use the desoldering wick to remove any excess solder left on the motherboard.
  6. PS3 Dual Shock 3 Controler Charging Port Replacement, Securing New Charging Port: 6 단계, 이미지 1개 중 1개
    • After the charging port is removed, place the new charging port into position.
    • Hold the new port in place by using a clip to keep it from moving.
  7. PS3 Dual Shock 3 Controler Charging Port Replacement, Soldering The New Port: 7 단계, 이미지 2개 중 1개 PS3 Dual Shock 3 Controler Charging Port Replacement, Soldering The New Port: 7 단계, 이미지 2개 중 2개
    • Tin the soldering iron before soldering the connections. This is done by applying a small amount of solder to the tip of the hot iron.
    • Solder the 9 pin connections that connect the charging port to the motherboard.
결론
To reassemble your device, follow instructions 1-3 in reverse order.
다른 16명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Attak
회원 가입일: 12/04/17
622 평판
안내서 1개를 작성함
댓글 5개
Shall DualShock3 require other than GND and VBUS for charging only
and does DS3 follow the standards of USB-miniB (eg: Data wires flipping).
Sony does have some fame to sacrifice standards over extra capability delivery.
JanLS - 답글
Would you guys happen to know, if my labeling is correct? I’m going to upgrade to USB-C.
https://imgur.com/a/RL68Yw5
Howling Beats - 답글
Thank you it's really useful, tips,
Alan - 답글
Thanks for this. But now there are four different USB charging ports, how to tell which one of them is suitable? kasynparts eg
kasynlife - 답글
please attak if you still using this platfrom i really need you to help me with a ps3 controller pins
Deyaa Alshapshiri - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 77
지난 30일: 279
전체 시간: 20,409
