주요 콘텐츠로 건너뛰기
PSP 300x D-Pad Replacement
mbnewsom
mbnewsom6 다른 기여자
최종 수정일 October 12, 2022
10 분
쉬움
일관성 없는 이미지
Steps for replacing malfunctioned directional pads in a Sony PSP-3000
필요한 것
부품
도구
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
더보기...
  1. PSP 300x D-Pad Replacement, Battery: 1 단계, 이미지 3개 중 1개 PSP 300x D-Pad Replacement, Battery: 1 단계, 이미지 3개 중 2개 PSP 300x D-Pad Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x D-Pad Replacement, Front Casing: 2 단계, 이미지 1개 중 1개
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    This will end your warranty, so do it on your own risk!
    Paweł Kasztura - 답글
    Even though warranties are long expired on these things.
    Vincent C. -
    “IF” your on this Site “I FIX IT(tm) to lean how to repair something on your own… you “Should NOT” be too concerned about warranty any longer, as if you were .. for your iPhone or Pad etc… you would have taken it to the supplier.. No??
    Barry Goian - 답글
  3. PSP 300x D-Pad Replacement: 3 단계, 이미지 2개 중 1개 PSP 300x D-Pad Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x D-Pad Replacement: 4 단계, 이미지 1개 중 1개
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x D-Pad Replacement: 5 단계, 이미지 1개 중 1개
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    “DON’T” forget to put your screws separately on a mag mat (Or sticky tape) so to 1) Not loose them & 2) Remember where they go as they may be of differing sizes. (Refer time the pictures also helps, but you can take a pic on your camera as you go to remind you also.
    Barry Goian - 답글
  6. PSP 300x D-Pad Replacement: 6 단계, 이미지 2개 중 1개 PSP 300x D-Pad Replacement: 6 단계, 이미지 2개 중 2개
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
    J’ai récemment fait cette réparation et le boîtier avant ne voulait pas venir à condition d’enlever les deux vis sur le boîtier arrière au niveau du joystick et de la croix directionnelle. Il manque donc selon moi une partie mais je peux me tromper !
    Valentin Boileau - 답글
  7. PSP 300x D-Pad Replacement, D-Pad: 7 단계, 이미지 2개 중 1개 PSP 300x D-Pad Replacement, D-Pad: 7 단계, 이미지 2개 중 2개
    • Peal up the rubber pad that is securing the D-pad buttons to the backside of the front casing.
    • Remove the D-pad and the rubber piece.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
mbnewsom
회원 가입일: 10/28/09
3,265 평판
안내서 11개를 작성함
댓글 한 개
Is it for 2000?
Kaio Igor - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 42
지난 30일: 156
전체 시간: 10,720
