주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PSP 300x Power Board Replacement
필요한 것
  1. PSP 300x Power Board Replacement, Battery: 1 단계, 이미지 3개 중 1개 PSP 300x Power Board Replacement, Battery: 1 단계, 이미지 3개 중 2개 PSP 300x Power Board Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
    댓글 쓰기
  2. PSP 300x Power Board Replacement, Front Casing: 2 단계, 이미지 1개 중 1개
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    댓글 쓰기
  3. PSP 300x Power Board Replacement: 3 단계, 이미지 2개 중 1개 PSP 300x Power Board Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
    댓글 쓰기
  4. PSP 300x Power Board Replacement: 4 단계, 이미지 1개 중 1개
    • Next, unscrew the two screws located at the top of the PSP.
    댓글 쓰기
  5. PSP 300x Power Board Replacement: 5 단계, 이미지 1개 중 1개
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    댓글 쓰기
  6. PSP 300x Power Board Replacement: 6 단계, 이미지 2개 중 1개 PSP 300x Power Board Replacement: 6 단계, 이미지 2개 중 2개
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
    댓글 쓰기
  7. PSP 300x Power Board Replacement, LCD Screen: 7 단계, 이미지 2개 중 1개 PSP 300x Power Board Replacement, LCD Screen: 7 단계, 이미지 2개 중 2개
    • Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
    댓글 쓰기
  8. PSP 300x Power Board Replacement: 8 단계, 이미지 3개 중 1개 PSP 300x Power Board Replacement: 8 단계, 이미지 3개 중 2개 PSP 300x Power Board Replacement: 8 단계, 이미지 3개 중 3개
    • Slowly lift the LCD screen off the PSP starting at the top edge corner.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Orientation of PSP is flipped in photo.
    댓글 쓰기
  9. PSP 300x Power Board Replacement: 9 단계, 이미지 2개 중 1개 PSP 300x Power Board Replacement: 9 단계, 이미지 2개 중 2개
    • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
    • Pull all four ribbon cables out.
    • Now remove the LCD screen and homebar from the PSP.
    댓글 쓰기
  10. PSP 300x Power Board Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the metal tab that lies above the LCD screen.
    • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
    댓글 쓰기
  11. PSP 300x Power Board Replacement, Power Board: 11 단계, 이미지 1개 중 1개
    • Using a spudger, lift up the lock and remove the ribbon cable from the motherboard
    댓글 쓰기
  12. PSP 300x Power Board Replacement: 12 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the screw located on the power switch board.
    댓글 쓰기
  13. PSP 300x Power Board Replacement: 13 단계, 이미지 1개 중 1개
    • Lift up and remove the power-switch board.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
mbnewsom
회원 가입일: 10/28/09
3,508 평판
안내서 11개를 작성함
1가이드 댓글
for power board you can skip 7-10 steps ,1 to 6 is remove front case , real work start at step 11 ,between those was taking apart sreen, but not need for power board replacement.
javi - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 42
지난 30일: 198
전체 시간: 24,186
