주요 콘텐츠로 건너뛰기
PSP 300xc Power Jack Replacement
필요한 것
  1. PSP 300xc Power Jack Replacement, Battery: 1 단계, 이미지 2개 중 1개 PSP 300xc Power Jack Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
    • Lift the battery out of the PSP.
  2. PSP 300xc Power Jack Replacement, Front Case: 2 단계, 이미지 1개 중 1개
    • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
  3. PSP 300xc Power Jack Replacement: 3 단계, 이미지 2개 중 1개 PSP 300xc Power Jack Replacement: 3 단계, 이미지 2개 중 2개
    • Remove four Phillips screws from the back of the PSP.
  4. PSP 300xc Power Jack Replacement: 4 단계, 이미지 1개 중 1개
    • Remove two Phillips screws from the top of the PSP.
  5. PSP 300xc Power Jack Replacement: 5 단계, 이미지 1개 중 1개
    • Remove a single screw from the bottom edge of the PSP.
  6. PSP 300xc Power Jack Replacement: 6 단계, 이미지 2개 중 1개 PSP 300xc Power Jack Replacement: 6 단계, 이미지 2개 중 2개
    • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
  7. PSP 300xc Power Jack Replacement, LCD: 7 단계, 이미지 1개 중 1개
    • Remove a single Phillips screw securing the home bar to the PSP 300xc.
  8. PSP 300xc Power Jack Replacement: 8 단계, 이미지 2개 중 1개 PSP 300xc Power Jack Replacement: 8 단계, 이미지 2개 중 2개
    • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
    • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
  9. PSP 300xc Power Jack Replacement: 9 단계, 이미지 1개 중 1개
    • Insert a spudger under the LCD, beside the black plastic tab.
    • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
  10. PSP 300xc Power Jack Replacement: 10 단계, 이미지 1개 중 1개
    • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
  11. PSP 300xc Power Jack Replacement: 11 단계, 이미지 3개 중 1개 PSP 300xc Power Jack Replacement: 11 단계, 이미지 3개 중 2개 PSP 300xc Power Jack Replacement: 11 단계, 이미지 3개 중 3개
    • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
    • Home bar cable
    • Microphone cable
    • LCD display data cable
    • Touchscreen cable
    • Be sure you are prying up on the retaining flap, not the socket itself
    • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
  12. PSP 300xc Power Jack Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the LCD from the PSP 300xc.
  13. PSP 300xc Power Jack Replacement, Home Bar: 13 단계, 이미지 3개 중 1개 PSP 300xc Power Jack Replacement, Home Bar: 13 단계, 이미지 3개 중 2개 PSP 300xc Power Jack Replacement, Home Bar: 13 단계, 이미지 3개 중 3개
    • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
    • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
    • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
    • The home bar should now lift out of the PSP 300xc.
  14. PSP 300xc Power Jack Replacement, Trigger Buttons: 14 단계, 이미지 2개 중 1개 PSP 300xc Power Jack Replacement, Trigger Buttons: 14 단계, 이미지 2개 중 2개
    • Remove both trigger buttons by lifting them off the PSP 300xc.
  15. PSP 300xc Power Jack Replacement, Power Switch Board: 15 단계, 이미지 1개 중 1개
    • Using a finger or spudger, flip up the retaining flap on the power switch board ribbon cable socket.
    • Pull the ribbon cable out of its socket.
  16. PSP 300xc Power Jack Replacement: 16 단계, 이미지 1개 중 1개
    • Using the flat end of a spudger, pry the power switch board up and off the PSP 300xc.
    • Remove the power switch board from the PSP.
  17. PSP 300xc Power Jack Replacement, Power Jack: 17 단계, 이미지 1개 중 1개
    • Remove a single Phillips screw securing the power jack to the PSP.
  18. PSP 300xc Power Jack Replacement: 18 단계, 이미지 1개 중 1개
    • Using the flat edge of a spudger, pry the small black tab away from the power jack to free it from the case.
  19. PSP 300xc Power Jack Replacement: 19 단계, 이미지 1개 중 1개
    • Disconnect the power jack from its connector on the motherboard by pulling it straight out of its socket.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Matthew Newsom
회원 가입일: 01/05/10
41,972 평판
안내서 67개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 32
전체 시간: 9,337
