주요 콘텐츠로 건너뛰기
PSP Go Analog Joystick Replacement
Miroslav Djuric
Miroslav Djuric5 다른 기여자
최종 수정일 May 7, 2024
20 분
조정
Use this guide to put a fresh analog joystick into the PSP Go!
필요한 것
부품
도구
더보기...
  1. PSP Go Analog Joystick Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 PSP Go Analog Joystick Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Unscrew the four Phillips screws on the back of the PSP Go.
    • Rotate the PSP so you can see the top of the device.
    • Unscrew the two Phillips screws next to the volume buttons.
  2. PSP Go Analog Joystick Replacement: 2 단계, 이미지 2개 중 1개 PSP Go Analog Joystick Replacement: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
    • Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
    • Be careful not to rotate the back cover from the bottom, as you will break the plastic screw holes on top of the device.
  3. PSP Go Analog Joystick Replacement, Top Cover: 3 단계, 이미지 1개 중 1개
    • Pull the top cover upwards gently from its housing.
  4. PSP Go Analog Joystick Replacement, Bottom Plate: 4 단계, 이미지 2개 중 1개 PSP Go Analog Joystick Replacement, Bottom Plate: 4 단계, 이미지 2개 중 2개
    • Remove the two Phillips screws holding the bottom plate.
    • Gently lift the bottom plate away from the device.
  5. PSP Go Analog Joystick Replacement, Analog Joystick: 5 단계, 이미지 1개 중 1개
    • Use a #00 Phillips screwdriver to remove both screws holding the analog joystick in place.
  6. PSP Go Analog Joystick Replacement: 6 단계, 이미지 2개 중 1개 PSP Go Analog Joystick Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a plastic opening tool to gently flip up the analog joystick's cable connector.
    • Use your fingers or tweezers to gently pull out the analog joystick cable from its connector.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Miroslav Djuric
159,501 평판
안내서 144개를 작성함
댓글 한 개
What about the plastic tab on the ribbon cable how do i attach the ribbon cable to the connector its very delicate
daniel - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 25
지난 30일: 91
전체 시간: 22,714
