주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Palm TX Display Replacement
필요한 것
    1. Palm TX Display Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Palm TX Display Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
      • Orient the device so that the display faces forward.
      • Remove the stylus from the right side.
      댓글 쓰기
    2. Palm TX Display Replacement: 2 단계, 이미지 1개 중 1개
      • Turn over the device so that the back panel faces forward.
      • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
      댓글 쓰기
    3. Palm TX Display Replacement: 3 단계, 이미지 2개 중 1개 Palm TX Display Replacement: 3 단계, 이미지 2개 중 2개
      • Rotate the device so that the display faces forward.
      • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
      • Pry along the crevice to loosen the back panel.
      • Repeat this process for the right side.
      댓글 쓰기
    4. Palm TX Display Replacement: 4 단계, 이미지 2개 중 1개 Palm TX Display Replacement: 4 단계, 이미지 2개 중 2개
      • Carefully pry the back panel to open the device.
      • Be careful not to break the wire that connects the battery pack to the motherboard.
      • When reassembling, snap the back panel back into place and then insert the top cover.
      댓글 쓰기
    5. Palm TX Display Replacement: 5 단계, 이미지 2개 중 1개 Palm TX Display Replacement: 5 단계, 이미지 2개 중 2개
      • Use a plastic opening tool to peel the battery pack from the back panel.
      • The battery pack is glued to the back panel so removing it may require considerable effort.
      댓글 쓰기
    1. Palm TX Display Replacement, Battery Pack: 6 단계, 이미지 2개 중 1개 Palm TX Display Replacement, Battery Pack: 6 단계, 이미지 2개 중 2개
      • Use a soldering iron to disconnect the battery wires from the motherboard.
      • For soldering instructions, you can view the Soldering Guide.
      댓글 쓰기
    1. Palm TX Display Replacement, Motherboard: 7 단계, 이미지 2개 중 1개 Palm TX Display Replacement, Motherboard: 7 단계, 이미지 2개 중 2개
      • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
      댓글 쓰기
    2. Palm TX Display Replacement: 8 단계, 이미지 2개 중 1개 Palm TX Display Replacement: 8 단계, 이미지 2개 중 2개
      • Lift the mother board out of the device.
      • A weak adhesive attaches the motherboard to the device.
      • The red wire in the picture will not be attached to your device at this point.
      댓글 쓰기
    1. Palm TX Display Replacement, Display: 9 단계, 이미지 1개 중 1개
      • Orient the device sideways, as shown in the picture.
      • Lightly push the front of the display to separate it from the front panel.
      • The battery in the picture will not be attached to the device at this point.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Spencer Lewson
회원 가입일: 01/19/11
793 평판
안내서 6개를 작성함
Cal Poly, Team 1-15, Amido Winter 2011 Cal Poly, Team 1-15, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G15
4 회원들
안내서 35개를 작성함
2가이드 댓글
It's not necessary to unsolder the battery back for this at all, as long as you're careful not to pull on the battery wires, all you have to do is leave it attached and make sure it doesn't move too far from the board.
Justin Clifford - 답글 공유
This stops with the display supposedly still firmly attached to the motherboard. How is this a display replacement procedure?
W. Lichtenberger - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 36
전체 시간: 3,955
