주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Palm TX Motherboard Replacement
필요한 것
    1. Palm TX Motherboard Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Palm TX Motherboard Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
      • Orient the device so that the display faces forward.
      • Remove the stylus from the right side.
      댓글 쓰기
    2. Palm TX Motherboard Replacement: 2 단계, 이미지 1개 중 1개
      • Turn over the device so that the back panel faces forward.
      • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
      댓글 쓰기
    3. Palm TX Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Palm TX Motherboard Replacement: 3 단계, 이미지 2개 중 2개
      • Rotate the device so that the display faces forward.
      • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
      • Pry along the crevice to loosen the back panel.
      • Repeat this process for the right side.
      댓글 쓰기
    4. Palm TX Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Palm TX Motherboard Replacement: 4 단계, 이미지 2개 중 2개
      • Carefully pry the back panel to open the device.
      • Be careful not to break the wire that connects the battery pack to the motherboard.
      • When reassembling, snap the back panel back into place and then insert the top cover.
      댓글 쓰기
    5. Palm TX Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Palm TX Motherboard Replacement: 5 단계, 이미지 2개 중 2개
      • Use a plastic opening tool to peel the battery pack from the back panel.
      • The battery pack is glued to the back panel so removing it may require considerable effort.
      댓글 쓰기
    1. Palm TX Motherboard Replacement, Battery Pack: 6 단계, 이미지 2개 중 1개 Palm TX Motherboard Replacement, Battery Pack: 6 단계, 이미지 2개 중 2개
      • Use a soldering iron to disconnect the battery wires from the motherboard.
      • For soldering instructions, you can view the Soldering Guide.
      댓글 쓰기
    1. Palm TX Motherboard Replacement, Motherboard: 7 단계, 이미지 2개 중 1개 Palm TX Motherboard Replacement, Motherboard: 7 단계, 이미지 2개 중 2개
      • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
      댓글 쓰기
    2. Palm TX Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Palm TX Motherboard Replacement: 8 단계, 이미지 2개 중 2개
      • Lift the mother board out of the device.
      • A weak adhesive attaches the motherboard to the device.
      • The red wire in the picture will not be attached to your device at this point.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Spencer Lewson
회원 가입일: 01/19/11
793 평판
안내서 6개를 작성함
Cal Poly, Team 1-15, Amido Winter 2011 Cal Poly, Team 1-15, Amido Winter 2011 회원
CPSU-AMIDO-W11S1G15
4 회원들
안내서 35개를 작성함
1가이드 댓글
Nicely done!
Matthew Newsom - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 14
지난 30일: 44
전체 시간: 4,057
