주요 콘텐츠로 건너뛰기
Palm Treo 650 Camera Replacement
cgood
cgood5 다른 기여자
최종 수정일 March 6, 2018
10 분
조정
학생이 작성 중
일관성 없는 이미지
잘못된 도구
This guide will help you access and replace the Treo's camera if it is no longer functional.
필요한 것
도구
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
더보기...
  1. Palm Treo 650 Camera Replacement, Battery and Stylus: 1 단계, 이미지 1개 중 1개
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. Palm Treo 650 Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Hold the button in the middle of the phone's back to remove the battery cover.
    • Slide the cover down to remove it, and set the cover aside.
  3. Palm Treo 650 Camera Replacement: 3 단계, 이미지 2개 중 1개 Palm Treo 650 Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
  4. Palm Treo 650 Camera Replacement, Case: 4 단계, 이미지 1개 중 1개
    • Remove the round, rubber cover to expose a screw that will be removed in the next step.
  5. Palm Treo 650 Camera Replacement: 5 단계, 이미지 2개 중 1개 Palm Treo 650 Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
    • Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
  6. Palm Treo 650 Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Pull the antenna outward to remove the antenna from the body of the phone.
  7. Palm Treo 650 Camera Replacement: 7 단계, 이미지 2개 중 1개 Palm Treo 650 Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Pry the back cover off using an iFixit opening tool.
    • Several small clips on the inside attach to the back cover.
  8. Palm Treo 650 Camera Replacement, Camera: 8 단계, 이미지 3개 중 1개 Palm Treo 650 Camera Replacement, Camera: 8 단계, 이미지 3개 중 2개 Palm Treo 650 Camera Replacement, Camera: 8 단계, 이미지 3개 중 3개
    • Remove the two 3.75 mm screws.
    • Pull off the logic board.
  9. Palm Treo 650 Camera Replacement: 9 단계, 이미지 3개 중 1개 Palm Treo 650 Camera Replacement: 9 단계, 이미지 3개 중 2개 Palm Treo 650 Camera Replacement: 9 단계, 이미지 3개 중 3개
    • Pull the rubber ring off of the camera.
  10. Palm Treo 650 Camera Replacement: 10 단계, 이미지 2개 중 1개 Palm Treo 650 Camera Replacement: 10 단계, 이미지 2개 중 2개
    • Pry off the metal camera case.
    • Lift up the camera, but do not remove. The connector must be detatched first.
  11. Palm Treo 650 Camera Replacement: 11 단계, 이미지 2개 중 1개 Palm Treo 650 Camera Replacement: 11 단계, 이미지 2개 중 2개
    • Pry off the camera connector plug.
    • Remove the camera.
결론
작성자
5다른 기여자 명과 함께
cgood
회원 가입일: 10/28/09
122 평판
안내서 7개를 작성함
Cal Poly, Team 19-3, Maness Fall 2009 Cal Poly, Team 19-3, Maness Fall 2009 회원
CPSU-MANESS-F09S19G3
4 회원들
안내서 18개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 2,154
